Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
lift problem
Post new topic    Yesterday's Tractors Forum Index -> Harry Ferguson
Tony in Mass.
PostPosted: Tue Jul 24, 2012 9:14 am    Post subject: lift problem Reply to specific post Reply with quote
Well, I can honestly say I didn't pay attention, but before I did anything to the TO35, the lift 'looked like, to the best of my recollection'- it seemed... to raise all the way up. I really didn't test it, came off the ground when I wanted it to. So lately I started working on it, dumped the hydraulic oil- milky, to work on the axle seals and lower link pin etc.... so now there is #90 gear oil from the MF dealer.. so it is the right stuff... but the arms still only raise half way. So if it was always like this, or I did something wrong is still in the air, but what can I check? Adjust?
Jerry/MT
PostPosted: Tue Jul 24, 2012 9:18 am    Post subject: Re: lift problem Reply to specific post Reply with quote
The oil shouldn"t be "gear oil"! It should be Permatran, or hytran, etc or whatever MF sells for transhydraulic fluid, UTF, or whatever you want to call it.
Tony in Mass.
PostPosted: Tue Jul 24, 2012 1:15 pm    Post subject: Re: lift problem Reply to specific post Reply with quote
I put in what the MF dealer sold me specificly for this tractor. It is labeled '90 gear oil'.
jon corbett
PostPosted: Tue Jul 24, 2012 4:45 pm    Post subject: Re: lift problem Reply to specific post Reply with quote
if mt te lift takes 30wght,why would u use 90wght?
Gearhead210
PostPosted: Tue Jul 24, 2012 6:02 pm    Post subject: Re: lift problem Reply to specific post Reply with quote
Tony, you have the correct oil in it. As long as this is actually a TO-35, and does not have multi power, it is supposed to use a 90 weight mineral oil (It is not 80-90 gear oil). A universal hy-tran oil will work, but that tractor was meant to have the 90 weight mineral oil, like you are using. As for the lift, lemme scratch my head for a bit.
john[mo]
PostPosted: Tue Jul 24, 2012 8:17 pm    Post subject: Re: lift problem Reply to specific post Reply with quote
90wt gear oil and 90wt mineral oil are two different kinds of lube.
JMOR
PostPosted: Wed Jul 25, 2012 5:30 am    Post subject: Re: lift problem Reply to specific post Reply with quote
Tony in Mass. wrote:
(quoted from post at 13:14:05 07/24/12) Well, I can honestly say I didn't pay attention, but before I did anything to the TO35, the lift 'looked like, to the best of my recollection'- it seemed... to raise all the way up. I really didn't test it, came off the ground when I wanted it to. So lately I started working on it, dumped the hydraulic oil- milky, to work on the axle seals and lower link pin etc.... so now there is #90 gear oil from the MF dealer.. so it is the right stuff... but the arms still only raise half way. So if it was always like this, or I did something wrong is still in the air, but what can I check? Adjust?
Why all the hash about right/wrong oil/ Right or wrong, it would not impact his problem of lifting ONLY half way?????
Inno
PostPosted: Wed Jul 25, 2012 8:02 am    Post subject: Re: lift problem Reply to specific post Reply with quote
Might need to be adjusted. John (UK) has a great set of instructions on how to do this.
john[mo]
PostPosted: Wed Jul 25, 2012 7:05 pm    Post subject: Re: lift problem Reply to specific post Reply with quote
try putting two blue tablets in with your gear oil maybe it will go all the way up!
Tony in Mass.
PostPosted: Wed Jul 25, 2012 8:23 pm    Post subject: Re: lift problem Reply to specific post Reply with quote
OK. So it took me a few minutes to get the punch line.
John wins the cigar!
JMOR
PostPosted: Wed Jul 25, 2012 8:28 pm    Post subject: Re: lift problem Reply to specific post Reply with quote
(quoted from post at 00:23:50 07/26/12) OK. So it took me a few minutes to get the punch line.
But will you be able to get it to go down?
john[mo]
PostPosted: Wed Jul 25, 2012 8:30 pm    Post subject: Re: lift problem Reply to specific post Reply with quote
if it stays up for more than 4 hours after you get it all the way up contact john[uk] for further instruction.
dakotamar
PostPosted: Mon Jul 30, 2012 7:58 am    Post subject: Re: lift problem Reply to specific post Reply with quote
I see some Canadian users here. I am looking for hydraulic oil for my TE20, are there any Candian suppliers of this oil and what are people using? I tried the Massy dealer and he is saying 80/90 but is not sure of this tractor.
View user's profile Yahoo Messenger
