| Author |
Message |
Kevin Little Regular
Posted: Wed Jul 25, 2012 4:07 pm Post subject: Removing a Drag Link |
OK, time for my next newbie stupid question.
I have a bad drag link and would like to replace it. How do I stop it from turning while I unscrew the nut? I know there should be some way to stop the shaft from turning, but I can't find it. Any help, pointers, diagrams written in crayon without using big words would be appreciated.
TIA,
Kevin |
| Back to top |
Tracy Brown Regular
Posted: Wed Jul 25, 2012 5:24 pm Post subject: Re: Removing a Drag Link |
Take a hammer & a sharp chisel and split the nut open. |
| Back to top |
samn40 Tractor Expert
Posted: Wed Jul 25, 2012 11:44 pm Post subject: Re: Removing a Drag Link |
If it is that bad that it needs replaced, don't waste time, just
either do as suggested, split with a chisel or cut it off with an
angle grinder or hacksaw. If it is good enough to save, then you
need to clamp it down tight into the taper and the nut will screw
off. Easy on any thing where the track rod end is in from below,
like on a 65. Just put the jack under it and lift the tractor!. On a
35 or TO20 you need a 'G' or maybe you call them a 'C' clamp
and about 8 inches of 1/2" flat bar. set the bar on the track rod
end and the drag link and put the clamp halfway along it and
tighten it real tight. Use the same methods to tighten in the new
one.
Sam |
| Back to top |
trac Long Time User
Posted: Fri Jul 27, 2012 4:10 am Post subject: Re: Removing a Drag Link |
If i'm not mistaking there should be a screw driver
slot on the bottom of the threads |
| Back to top |
John(UK) Long Time User
Posted: Sat Jul 28, 2012 2:05 am Post subject: Re: Removing a Drag Link |
As has been said, press the tapered pin into the Steering Lever the best way you can so that it will hold and then you should be able to unscrew the nut....JohnUK) |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
