Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
Cub cadet PTO problems
Post new topic    Yesterday's Tractors Forum Index -> Garden Tractors
Achodges1
PostPosted: Sun Jul 29, 2012 9:16 am    Post subject: Cub cadet PTO problems Reply to specific post Reply with quote
I inherited my dad's Cub Cadet 149. Nice tractor but needed some TLC. The Pto clutch lasted about half an hour then wouldn't engage. Upon inspection I discovered it had been worn out for years and readjusted untill the thrust button and fingers were worn away. Installed a rebuild kit, new thrust button, fingers, bearing and springs. Got everything back together and the PTO works as it should. My problem is I can't get the wear button to hold together. First try it lasted about 5 seconds. Took the mount to a machinist had him resurface the face to get a smoothe surface( It had worn away at an angle ).Reinstalled a new button and tried again. Seemed that all was well. It held up at idle and low rpm but at full throttle it gave way again. The wear button surface does not look parallel to the thrust button. Looks like it never has been since new ( mount looks welded crooked ). Could this be my problem ?
wisbaker
PostPosted: Sun Jul 29, 2012 9:19 am    Post subject: Re: Cub cadet PTO problems Reply to specific post Reply with quote
There's a wear button on the clutch AND a fiber mushroom shaped thing on the clutch lever do you have both????
Achodges1
PostPosted: Sun Jul 29, 2012 10:52 am    Post subject: Re: Cub cadet PTO problems Reply to specific post Reply with quote
Yes. It's the mushroom shaped wear button that keeps comeing apart.
ray hofstetter
PostPosted: Sun Jul 29, 2012 12:02 pm    Post subject: Re: Cub cadet PTO problems Reply to specific post Reply with quote
All of the ones I've worked on have been perfectly lined-up....
ray hofstetter
PostPosted: Sun Jul 29, 2012 12:26 pm    Post subject: Re: Cub cadet PTO problems Reply to specific post Reply with quote
Also, is the clutch adjusted properly? If not, it'll eat the button off too.
Bill Lisbon
PostPosted: Sun Jul 29, 2012 6:00 pm    Post subject: Re: Cub cadet PTO problems Reply to specific post Reply with quote
I bought brass button from a guy on E-bay. Had very good luck with them. Your hole may be worn try a dab of JB weld when you install a new button.
Achodges1
PostPosted: Mon Jul 30, 2012 9:24 am    Post subject: Re: Cub cadet PTO problems Reply to specific post Reply with quote
Thanks for the replies. I am going to heat up the arm that carries the button and get it parallel with the clutch. Install one more fiber button and try that. If it fails I'll get one made of something else.
stronics
PostPosted: Tue Jul 31, 2012 2:33 am    Post subject: Re: Cub cadet PTO problems Reply to specific post Reply with quote
All that has been said will help for sure but the newer replacment button doesn't seem to be the same material as original ones were. I found an old stock one for mine and was a different ball game.
David
