| Author |
Message |
Ron J. New User
Posted: Sat Aug 04, 2012 2:16 pm Post subject: Need PTO seal part number |
Hi. I'm replacing the PTO seal on my Fergy TO-30. I removed the old seal, but there was no visable part number on it. Can anyone help me out with a replacement seal number? Thanks, RJ. |
| Back to top |
Bruce(OR) Long Time User
Posted: Sat Aug 04, 2012 3:05 pm Post subject: Re: Need PTO seal part number |
Your local Case dealer can help you with no problems. This site also has your part. |
| Back to top |
Richard L Tractor Expert
Posted: Sat Aug 04, 2012 3:34 pm Post subject: Re: Need PTO seal part number |
New Holland dealer will probably have it also especially if they used to be a ford dealer. According to this site the original number was 195763M1 the dimensions are 2.45 OD, 1-5/8 ID and 5/8" wide. |
| Back to top |
John(UK) Long Time User
Posted: Sun Aug 05, 2012 4:19 am Post subject: Re: Need PTO seal part number |
The oil seal can be purchased locally from anyone who sells oil seals. The size is:-
1-5/8" x 2-1/2" x 7/8", the seal they will often give you is narrower than this but this seal need a seal protector on it then it wont get damaged by grass etc wrapping around it. This protector is usually made of leather, but it could be made of something else now. The narrower seal is no use for this purpose or you will be replacing it again quite soon. You should check the collar on the PTO shaft that the lip of the seal rubs against. If it is marked at all, in any way, it will damage the seal lip and it should be replaced.Use some grease on this collar when you slide the seal onto it. When you refill with oil, use Multi-grade 10W/30 which is a lot better than the original oil that was specified...John(UK)....fergusontractors @ hotmail.com |
| Back to top |
Ron J. New User
Posted: Mon Aug 13, 2012 6:21 pm Post subject: Re: Need PTO seal part number |
Thank you very much for the great information. RJ. |
| Back to top |
Ron J. New User
Posted: Mon Aug 13, 2012 6:24 pm Post subject: Re: Need PTO seal part number |
Thanks Bruce, I found it on this site after I posted. I appreciate it. RJ. |
| Back to top |
Ron J. New User
Posted: Mon Aug 13, 2012 6:28 pm Post subject: Re: Need PTO seal part number |
Thank you Richard, I found it on this site after I posted, and used the dimensions and part number to order it from my bearing supplier I appreciate it. RJ |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
