soybeans for hay
Chas.Ont.
PostPosted: Sat Aug 04, 2012 2:35 pm    Post subject: soybeans for hay Reply to specific post Reply with quote
My soy crop is stunted by the drought. A neighbour asked if I consider cutting it for hay (which is in short supply).
Question. Does it decient hay?
Chas.
rufus80
PostPosted: Sat Aug 04, 2012 3:01 pm    Post subject: Re: soybeans for hay Reply to specific post Reply with quote
I have heard about cutting soybeans for silage but not for hay.
TGIN
PostPosted: Sat Aug 04, 2012 5:02 pm    Post subject: Re: soybeans for hay Reply to specific post Reply with quote
Dad told me they baled them back in the 50s for the dairy cows . By the time the stocks were dry the leaves were powder dry and ya had to bale them with the dew on so the leaves did not blow away . Said the cows loved them .
Brendon-KS
PostPosted: Sat Aug 04, 2012 6:32 pm    Post subject: Re: soybeans for hay Reply to specific post Reply with quote
There was a lot of bean hay put up in our area last year and it is going on again this year due to the drought. I've heard that you need to cut them before the leaves turn too yellow; otherwise, you end up with sticks and powder. If handled correctly it appears to make decent hay, at least better than nothing.
Eldo case
PostPosted: Sat Aug 04, 2012 6:36 pm    Post subject: Re: soybeans for hay Reply to specific post Reply with quote
Hope this helps you!!!!!
CropWatch
Nebraska crop production & pest management information
Navigation
Home
Corn
Dry Beans
Forages
Organic
Sorghum
Soybeans
Wheat
Bioenergy Crops
Other Crops
Fruits & Vegetables (GAPs)
Potato
Sugar Beets
Related Topics
Economics & Marketing
Pest Management
Precision Agriculture
Soil Management
Tillage/No-Till Systems
Variety Testing
Genetic Improvement
Farm Research
Youth
Military Resources
Drought Resources image and link to DroughtResources.unl.edu
eXtension image - link to Extension.org
Ask an Expert
Ask an Expert
Ask a question. Send a photo.
Connect with UNL crop experts.
Email this page Email this page Subscribe to email updates Subscribe Print this article Print View RSS feed RSS
July 27, 2012
Salvaging Soybeans as Hay or Silage
Rain-fed soybeans may still have an opportunity to produce yield in areas that receive sufficient and timely rains. If that’s not the case for your dryland soybeans, you may want to salvage them as hay or silage.
When made correctly, soybean hay and silage can have feeding values similar to those for alfalfa.
Harvest soybean forage when leaves start to turn yellow, just before they drop off. It’s especially important to harvest before a freeze to prevent rapid leaf loss.
Making Hay. Soybean hay is challenging to make. The stems are quite woody and dry slowly. Be sure to condition or crimp the hay to hasten stem dry down. In contrast to the stems, soybean leaves dry quickly and then become crumbly. Avoid raking the fragile leaves, which can contribute to yield loss and a much lower feed value. If you must rake to merge windrows for baling, do it within one day of cutting. Do not rake to hasten drying as leaf loss will be severe.
Making Silage. Making good soy silage is less risky if you have silage equipment and do it right. I prefer mixing chopped soybeans with corn or sorghum as they are being ensiled, but that’s not always possible. For straight soy silage:
Get a good, clean chop.
Uniformly add a silage inoculant designed for legumes like alfalfa.
Add about one bushel of cracked corn or 50 pounds of molasses to each ton of wet silage to aid fermentation.
Pack soy silage especially well.
Obviously, you would rather harvest a good bean crop than make hay or silage from it, but when drought and heat prevent a good bean crop, hay or silage may be a good alternative.
Bruce Anderson
Extension Forage Specialist
Eldo case
PostPosted: Sat Aug 04, 2012 6:42 pm    Post subject: Re: soybeans for hay Reply to specific post Reply with quote
Also make sure they have not been sprayed with something that needs a with drawl time. Like a pesticide. Could be trouble. Just and after thought. Hope I was some help.
LAA
PostPosted: Sat Aug 04, 2012 7:06 pm    Post subject: Re: soybeans for hay Reply to specific post Reply with quote
Forage type Soybeans planted and managed for hay make hay as good as Alfalfa, stunted, douthed out row crop beans make a passable brood cow wintering hay if cut before all the leaves dry out and fall off. Even green lush soybeans are not hard to cure if cut with a moco -- windrow and roll the hay and you won't lose many leaves.
notjustair
PostPosted: Sun Aug 05, 2012 6:01 am    Post subject: Re: soybeans for hay Reply to specific post Reply with quote
All the beans here are a loss. Some don't look too bad but never set pods. Neighbor is getting ready to make hay with hers. She had the ag guy out and he's just baffled by it all. He's never seen it like this. Sounds like a dance to get them just before they drop leaves.
Erik Ks farmer
PostPosted: Sun Aug 05, 2012 7:35 am    Post subject: Re: soybeans for hay Reply to specific post Reply with quote
Thanks Eldo Case, I just posted a similar topic in tractor talk.
IHcollecter_94
PostPosted: Mon Aug 13, 2012 8:54 pm    Post subject: Re: soybeans for hay Reply to specific post Reply with quote
Soybeans were first brought to the US for hay. Just last year I cut some for hay and the animals would eat it before the alfalfa or grass. But be careful raking it because the leaves will fall off pretty easy
Post new topic    Yesterday's Tractors Forum Index -> Using Your Tractor & Crop Talk All times are GMT - 8 Hours
