Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
580b wont push hard
Post new topic    Yesterday's Tractors Forum Index -> Crawlers, Dozers, Loaders and Backhoes
Greg M L
PostPosted: Sat Aug 04, 2012 3:29 pm    Post subject: 580b wont push hard Reply to specific post Reply with quote
I have a 580b that will stop when it goes into a pile. The torque converter pressure guage is in the green and I checked it with a manual guage - the pressure is good. I checked the pump pressure at the hydraulic filter as the manual says and it is good too. How do I know if the torque converter is failing or if it is the clutches in the power shuttle?
Case Nutty 1660
PostPosted: Sat Aug 04, 2012 3:38 pm    Post subject: Re: 580b wont push hard Reply to specific post Reply with quote
does it have good power in rev? most times the FWD pack wears before the REV ones, and on the converter not saying they don't fail but I have sold/repaired them since 1966 and have only seen and replaced one converter and it at least would still put power to the wheels but it was flooding the system with alumiumum pieces, just a good guess would be worn shuttle disc's cnt
george md
PostPosted: Sat Aug 04, 2012 5:49 pm    Post subject: Re: 580b wont push hard Reply to specific post Reply with quote
Check your throttle linkage , they get really
lazy if off by 100 to 200 rpm.
george
Dave8N in Pa
PostPosted: Mon Aug 06, 2012 9:22 am    Post subject: Re: 580b wont push hard Reply to specific post Reply with quote
I have a 580B and the shuttle stops working when it gets warmed up good. Still works in reverse. It acts like the clutch pack is not sqeezed together hard enough. Is there any chance it could be something else. I hate to think about spitting the old girl in half.
Case Nutty 1660
PostPosted: Tue Aug 07, 2012 4:30 am    Post subject: Re: 580b wont push hard Reply to specific post Reply with quote
from what I have seen through the years no, sorry but my guess is that they are just wore past the point to where they can still lock up and drive, its not that bad a job once you start, remove the backhoe and backhoe mounts and split by rolling the rear axle away from the front half usally takes me about three hours to have one tore down, I do recomend a Case service manual as they have step by step instructions cnt
the tractor vet
PostPosted: Tue Aug 07, 2012 9:24 am    Post subject: Re: 580b wont push hard Reply to specific post Reply with quote
if THE FORWARD CLUTCH PAC IS TOAST I feel sorry for you . Years back i got coned into working on a 580 B with the same problem . First off it was no picnic splitting it as i am not set up for working on Ind. When i got it apart and tore down the forward clutch pac was history . Having no contacts other then The Case dealer i am stuck with them . Come to find out that what i need to fix this thing are no longer available from case and had to get a whole unit that WOULD fit with some mods to it for use on a shuttle with out PTO . . And here was the kicker to all this , they did not know what part numbers were they needed to get to put in the PTO unit to plug the thru hole to block the oil flow where the seals went on the Thru PTo shaft as they had to be PLUGGED . .Anyway that unit cost back then over 4300 bucks plus all the rest of the pieces and parts . The guy that owned the machine had almost as much as he paid for it in repairs . I learned one thing , STICK WITH a gear drive as a clutch is a lot less money.
Case Nutty 1660
PostPosted: Tue Aug 07, 2012 10:21 am    Post subject: Re: 580b wont push hard Reply to specific post Reply with quote
sorry you had a bad experiance with one we sold right at one thousand units between 1966 and 1976, all of them with the power shuttle and not one mechanical shuttle, how long ago was this they said they were not available? last one I did was about four years ago had no trouble then getting parts but with Fiat involved I could see things getting only worse,, as to the removing the pto should only have taken a soft plug to plug the hollow shaft front and rear, if you still used the original one, and the power shuttle was a good design as they were usally good for 3000-5000 hrs if used correctly before a rebuild, also after you do the first one they are not really so bad at least to me if I had parts in stock I could do one in a 10-12 hr day complete easy if I ddi brakes at the same time it added 3-4 hrs also cnt
the tractor vet
PostPosted: Thu Aug 09, 2012 4:54 pm    Post subject: Re: 580b wont push hard Reply to specific post Reply with quote
It has been ten years since i did that one . And According to Southeast Equipment nothing was available for that ya had to get the whole unit . The soft plugs were not of a std size and i had a machine shop make them . If the parts were available i could have rebuilt it . as for the splitting of it what a pain . I'll stick to splitting wheel tractors , i knew there was a reason that i would not do industrial and trucks.
Dennis K (WA)
PostPosted: Thu Aug 09, 2012 5:59 pm    Post subject: Re: 580b wont push hard Reply to specific post Reply with quote
As I remember the 580B used two different brands of shuttles. One being Rockford and the other Twin Disc. Twin Disc being the more expensive to rebuild. So maybe one of them have parts availability issues. I believe Twin Disc is part of Allison now.
Good luck
Dennis
