Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
engine exchange
Post new topic    Yesterday's Tractors Forum Index -> Allis Chalmers
Idahoho
PostPosted: Sun Aug 05, 2012 10:32 am    Post subject: engine exchange Reply to specific post Reply with quote
I am replacing a 649T diesel engine with a 670T that requires adding a aftercooler in a 8010 A/C tractor. What is a good method to fit/connect a aftercooler or how can the use of a aftercooler be mitigated?
Thanks,
Idahoho
glr62
PostPosted: Thu Aug 09, 2012 5:58 pm    Post subject: Re: engine exchange Reply to specific post Reply with quote
don't need it. 8010 has dry clutch right? don't know if flywheels will work
Idahoho
PostPosted: Fri Aug 10, 2012 1:41 pm    Post subject: Re: engine exchange Reply to specific post Reply with quote
glr62, thank you for responding to our question.
The tractor is a power driven clutch (per manual).
We will work on the engine tomorrow. Now we need to find out why the 670T does not require a intercooler. We probably should just stick with the 649T engine, but could not locate a good one!
Idahoho
Aaron SEIA
PostPosted: Fri Aug 10, 2012 4:54 pm    Post subject: Re: engine exchange Reply to specific post Reply with quote
I assume you are putting a 426 where a 301 was. The higher horse 426 was intercooled using a water to air cooler bolted to the engine. I assume you could fab an air to air cooler if you were so inclined. If the 8010 radiator has less cooling capacity than the 8050 and 8070 that would have been intercooled, you will certainly have overheating issues if you use all the ponies the bigger motor makes.
AaronSEIA
glr62
PostPosted: Fri Aug 10, 2012 6:57 pm    Post subject: Re: engine exchange Reply to specific post Reply with quote
what happened to yours? got one that has been in a combine, was going to put in a 190xt, but too many things just would not fit.
Idahoho
PostPosted: Fri Aug 10, 2012 7:38 pm    Post subject: Re: engine exchange Reply to specific post Reply with quote
Thank you Aaron for sharing your knowledge about the cooler. Sure helps.
Idahoho
Idahoho
PostPosted: Fri Aug 10, 2012 8:09 pm    Post subject: Re: engine exchange Reply to specific post Reply with quote
Hi glr62. Our tractor was purchased used and it perfoprmed very well for us until recently. It now uses oil and is noisy. We had a mechanic drop the pan & he told us the crackshaft is worn. We are hoping to exchange out to a better used engine and avoid the high cost to have our engine rebuilt. My son found the 670T engine (out of a combine) & thought he and I could handle the job (until we became aware of the cooler issue).
Idahoho
Aaron SEIA
PostPosted: Sat Aug 11, 2012 3:57 am    Post subject: Re: engine exchange Reply to specific post Reply with quote
I still don't see how the cooler is an issue. Does the 426 you are putting in have one on it? You really shouldn't need one and the 8010 rear end doesn't need the extra power the cooler would let you make. I would almost think you could find a 301 out of something that would be easier to put in than a 426. Or spend the money on a rebuild and know what you have. Used motor could do the same thing yours did the first hour you run it.
AaronSEIA
Idahoho
PostPosted: Sat Aug 11, 2012 8:35 am    Post subject: Re: engine exchange Reply to specific post Reply with quote
Hi Aaron, Thank you for the help. I think we will continue trying to locate a 301 somewhere as you suggested and forget the 426. We really like the Allis Chalmers tractor and will keep it.
Idahoho
c_mayer
PostPosted: Wed Aug 15, 2012 12:42 pm    Post subject: Re: engine exchange Reply to specific post Reply with quote
By the time you swap engines, you have almost the same amount of labor as just overhauling yours. You have to pull the camshaft to swap the front plate to make it fit into the tractor. Basically dismantle the whole engine less crank and pistons, and then re-assemble.
As a dealer, if you aren't sure of your ability to swap the engine, then get yours rebuilt. We have done this in the past for customers that refused to rebuild them, and it was basically the same cost....and you still have a used engine.
Feel free to give me a call if you'd like, I would be glad to help you anyway I can.
Chris Mayer
Mayer Farm Equipment
Jeffersoncille, OH
800-996-2937
