| Author |
Message |
JAMES H. COBLE New User
Posted: Sun Aug 05, 2012 3:48 pm Post subject: 1941 WC ALICE CHALMERS |
I AM REBUILDING THIS 1941 WC SERIAL #132941 AND I NEED TO KNOW WHAT KIND OF ENGINE IT HAS IN IT. IT HAS 4 CYLINDERS AND IT HAS NO NAME ON THE BLOCK. I NEED TO GET RINGS AND DON'T KNOW HOW.I LIVE IN SARDIS MS AND MY PHONE NUMBER IS 1-662-526-9522 , IF YOU CAN HELP PLEASE CALL OR E-MAIL; ME . . THANKS |
| Back to top |
JMS/.MN Tractor Guru
Posted: Sun Aug 05, 2012 4:02 pm Post subject: Re: 1941 WC ALICE CHALMERS |
It"s an AC built 201 cu in engine, 4 inch bore, 4 inch stroke. Rebuild kits available through AGCO, plus many other suppliers, including Yt Mag. |
| Back to top |
old Tractor Guru
Joined: 12 Mar 2000 Posts: 50459 Location: Lake of the Ozarks area of MO
Posted: Sun Aug 05, 2012 4:18 pm Post subject: Re: 1941 WC ALICE CHALMERS |
Well being a styled WC it should have the same engine as the WC/WD but and this is the big thing is you have no idea what may or may not have been done to it over the years so a person pretty much need to open it up then order the parts because it could have been modified in the 50 plus years is has run |
| Back to top |
Jerry Coulter Long Time User
Posted: Sun Aug 05, 2012 5:02 pm Post subject: Re: 1941 WC ALICE CHALMERS |
Like Old says, you better open it up first. Over the years it might have been overhauled with an over-bore 4-1/8" kit which would take different rings. It should have flat top pistons. If you find crater pistons, then it likely would have a WD45 crank installed. |
| Back to top |
Ohiowd45 Guest
Posted: Mon Aug 06, 2012 8:50 am Post subject: Re: 1941 WC ALICE CHALMERS |
Does the unstyled WC share the same engine as the styled WC? |
| Back to top |
Butch(OH) Tractor Expert
Posted: Mon Aug 06, 2012 9:21 am Post subject: Re: 1941 WC ALICE CHALMERS |
Basicaly yes. But improvements started almost imediately and continued until the end of 201 production. The 201 in a late WD is quite a differant animal than a 1934 WC engine in features and performance. |
| Back to top |
Posted: Mon Aug 06, 2012 5:22 pm Post subject: Re: 1941 WC ALICE CHALMERS |
I PULLED THE PISTONS AND THE PISTONS ARE CRATOR SHAPED ON TOP NOT THE FLAT SERFACE , DOES THIS MEAN THAT IT HAS BEEN REBUILT BEFORE AND I NEED TO GET SOMEONE TO MEASURE THE RING THAT IS IN THERE NOW.ALSO THIS IS MY FIRST TIME TO REBUILD A MOTOR AND I AM JUST FEELING MY WAY ALONG . THANKS FOR YOUR RESPONSE. |
| Back to top |
Aaron SEIA Long Time User
Posted: Tue Aug 07, 2012 11:28 am Post subject: Re: 1941 WC ALICE CHALMERS |
Probably has had WD45 or M&W pistons put in it. Need to pull a piston and see for sure. Guess I'll be the first to say it, but I'd put 4 new sleeves and pistons in if it were me. The pistons in it now could be sloppy loose, the sleeves could be wore and have a large groove at the top. New rings won't fix either of those problems and without taking the groove off the sleeve you could smash your newly installed top ring.
AaronSEIA |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
