| Author |
Message |
OldMoIron Regular
Posted: Sun Aug 05, 2012 5:41 pm Post subject: CA govenor |
I need some tips on tuning up my CA it seems it lags under pull. As when letting out the clutch in 3rd gear. Is there some adjustment that can be done. thanks |
| Back to top |
Dick L Tractor Guru
Posted: Sun Aug 05, 2012 6:35 pm Post subject: Re: CA govenor |
What all have you done to the engine? |
| Back to top |
old Tractor Guru
Joined: 12 Mar 2000 Posts: 50449 Location: Lake of the Ozarks area of MO
Posted: Mon Aug 06, 2012 7:30 am Post subject: Re: CA govenor |
A problem like that can be caused by many things. Needing a simple tune up or a carb rebuild or as simple as a weak spring. Hard for us to help you with out more info as to what you may or may not have done already |
| Back to top |
OldMoIron Regular
Posted: Mon Aug 06, 2012 3:36 pm Post subject: Re: CA govenor |
thanks Dick for reply, The thing has sit for awhile. Drained old gas,put in new, cleaned air filter/oil, cleaned plugs, checked wires for breaks, filed points readjusted. reset dwell. checked air fuel mixture, and timing. sorry to go on and on, Trying to let ya know. thanks |
| Back to top |
Dick L Tractor Guru
Posted: Tue Aug 07, 2012 7:49 am Post subject: Re: CA govenor |
Only a guess but I would think it would come around with some hard work and a can of sea foam. Half in the crankcase and half in a half tank of gas. It sounds like it is a bit shy on compression or HP. Same deal when you are talking third gear.
A governor is a RPM limitor or is to hold the RPM up under load provided you have the HP to hold that load at that RPM.
My thoughts come from the fact that it sounds like nothing has really been changed in the engine by you before the problem started. If the engine is not wore out working it will get the rings to hold compression up. You can do a compression check as is and them add a few squirts of oil in the spark plug hole and re check the compression before the oil can seep by the rings. If the compression does come up the working then engine should work. |
| Back to top |
OldMoIron Regular
Posted: Tue Aug 07, 2012 5:48 pm Post subject: Re: CA govenor |
thanks for your help |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
