| Author |
Message |
Rob Lewellen New User
Posted: Wed Aug 08, 2012 6:28 am Post subject: John Deere 4430 clutch problem |
I have a 1975 John Deere 4430 quad range that the clutch has started slipping in all gears. System pressure measures 2250 psi. At the clutch port I only have 50 psi and oil is airated. I removed the rockshaft housing and checked the cast iron plate underneath for cracks and it was ok. Now I'm stumped. Any help greatly appreciated!! |
| Back to top |
buickanddeere Tractor Guru
Joined: 31 May 2003 Posts: 23638 Location: in front of computer
Posted: Fri Aug 10, 2012 3:54 am Post subject: Re: John Deere 4430 clutch problem |
Given the vintage and hours. Odds are it needs the uptime trans oil pump. A clean screen and new filters. Is the pto valve moving full stroke to. 100% open? |
| Back to top |
JDseller Tractor Guru
Joined: 09 Jul 2010 Posts: 4483 Location: North-East Iowa
Posted: Fri Aug 10, 2012 7:25 pm Post subject: Re: John Deere 4430 clutch problem |
The problem is in the Hi-Lo clutch pack not the main clutch. The power shift Hi-Lo(1-2 or 3-4 shift) uses oil pressure to engage. 50 PSI is way low. It should be in the 135 PSI range. You need to split it and check the Hi-Lo clutch pack out. I would bet that you have blown an oring in a piston. I would rebuild it completely while I was in there. |
| Back to top |
430WLPG Long Time User
Posted: Sun Aug 12, 2012 4:00 pm Post subject: Re: John Deere 4430 clutch problem |
The main clutch shares the same oil with the two speed and the pressure should be 185psi if it's been run long at 50psi they are all burnt up |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
