Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
TO-30 Front Axel hits Lower Rad Hose
Post new topic    Yesterday's Tractors Forum Index -> Harry Ferguson
rekerkayak
PostPosted: Sat Aug 11, 2012 4:50 pm    Post subject: TO-30 Front Axel hits Lower Rad Hose Reply to specific post Reply with quote
My To-30 is still a working tractor. She's a great tractor for my little place.
Hilly travel where I live causes the front axel to pivot up just enough to break the lower radiator hose. The axel goes just high enough to cause a scissors effect at the radiator outlet.
Tried everything I could think of any ideas out there??
Richard L
PostPosted: Sat Aug 11, 2012 5:55 pm    Post subject: Re: TO-30 Front Axel hits Lower Rad Hose Reply to specific post Reply with quote
As soon as you can please take a very good look at the front axle pin. It sounds to me as it may have needed replacing some time ago. It won't be good if you are on a side of a hill and it breaks.
Bruce(OR)
PostPosted: Sat Aug 11, 2012 7:30 pm    Post subject: Re: TO-30 Front Axel hits Lower Rad Hose Reply to specific post Reply with quote
Yep! Sounds a bit worse than the junk yard refugee 2N in the front yard. It has the same problem. Hence another reason for it"s gathering moss "till I get a round tuit.
Right after the 8N and what ever else comes along such as her van with a busted hose.
"It is difficult to remind ourselves the original objective was to drain the swamp when up to you a** in alligators."
trac
PostPosted: Sun Aug 12, 2012 4:33 am    Post subject: Re: TO-30 Front Axel hits Lower Rad Hose Reply to specific post Reply with quote
The axle bushing also needs replacing with new pin it's not that hard to do.
Bob (Aust)
PostPosted: Mon Aug 13, 2012 1:33 am    Post subject: Re: TO-30 Front Axel hits Lower Rad Hose Reply to specific post Reply with quote
And the radius rods will also be bent.
rekerkayak
PostPosted: Tue Aug 14, 2012 7:46 am    Post subject: Re: TO-30 Front Axel hits Lower Rad Hose Reply to specific post Reply with quote
Well......
Ignorance was bliss..
Not to hard ya say??
overhead
PostPosted: Tue Aug 14, 2012 3:38 pm    Post subject: Re: TO-30 Front Axel hits Lower Rad Hose Reply to specific post Reply with quote
Not too hard, no. It required a trip to the machine shop for me as I had to get the center beamed drilled out to fit the newer sized bushing, and I also had to replace the axle support because the pin had turned what should be a round hole into an oval, but it was not very technically challenging at all. I had zero experience working on tractors, but I did have lots of experience on on cars, ATV, motorcycles, etc.
rekerkayak
PostPosted: Wed Aug 15, 2012 4:53 am    Post subject: Re: TO-30 Front Axel hits Lower Rad Hose Reply to specific post Reply with quote
got a look at it last night and if it's bad I can't tell. Looks like everything is there.
Radius rods may be bent slightly??
Anything special I need to look for or a way I can test or measure to tell for sure??
overhead
PostPosted: Wed Aug 15, 2012 5:57 am    Post subject: Re: TO-30 Front Axel hits Lower Rad Hose Reply to specific post Reply with quote
I have only completed this repair once, so I am sure there are others here that can answer better than I can.
Mine was obviously broken, I did not have to measure anything.
rekerkayak
PostPosted: Wed Aug 15, 2012 6:26 am    Post subject: Re: TO-30 Front Axel hits Lower Rad Hose Reply to specific post Reply with quote
Yup-I saw this post, great info. Mine is not broken and looks pretty good, compared to this one.
overhead
PostPosted: Wed Aug 15, 2012 7:07 am    Post subject: Re: TO-30 Front Axel hits Lower Rad Hose Reply to specific post Reply with quote
I imagine if you jack the tractor up so that the front axle moves freely you could tell whether their were play in the center beam bushing/pin. Hopefully someone else with more experience will chime in.
Bob (Aust)
PostPosted: Thu Aug 16, 2012 12:55 am    Post subject: Re: TO-30 Front Axel hits Lower Rad Hose Reply to specific post Reply with quote
Changing the front pivot pin and bushes is relatively simple. Depending on what tooling you have, you may need to have the old bushes pressed out and new bushes presse in.
The radius arms will be bent and can be straightened in a press - with care!
