| Author |
Message |
Fergienewbee Tractor Expert
Posted: Sun Aug 12, 2012 12:09 pm Post subject: Starter Does Not Engage Flywheel |
My T0-30 started fine last time. Yesterday the starter just made a whirring noise and did not engage. I've had to by-pass the starter switch and go right from the battery to the starter the last few times. Waiting for when BIL has time to look at it. Would that cause the starter problem?
Larry |
| Back to top |
John(Ont) Regular
Posted: Sun Aug 12, 2012 1:14 pm Post subject: Re: Starter Does Not Engage Flywheel |
Bendix could be sticking on the shaft and not engaging or teeth on flywheel missing. Turn engine over 1/4 turn by hand and try. |
| Back to top |
Jerry/MT Tractor Guru
Joined: 22 Jul 2003 Posts: 9866 Location: Western Montana
Posted: Sun Aug 12, 2012 4:52 pm Post subject: Re: Starter Does Not Engage Flywheel |
The starter drive clutch pack is worn out or not moving to engage the ring gear. The ring gear could also be slipping on the flywheel. I had one knock the ring gear off the flywheel! It was the old early style TO-20 flywheel a PO had put on my TO-30. |
| Back to top |
Bob (Aust) Tractor Expert
Joined: 06 Sep 2007 Posts: 2212 Location: Queensland, Australia
Posted: Mon Aug 13, 2012 1:14 am Post subject: Re: Starter Does Not Engage Flywheel |
Hmmm. I disagree. If the starter engages with a lead direct from battery to starter motor, I don't think it is mechanical.
To me this sentence:
"I've had to by-pass the starter switch and go right from the battery to the starter the last few times."
Suggests possibly an electrical problem - bad earth, high resistance in the starter switch, corrosion in the leads, battery reached its "use by date" etc.
Bob in Oz
'53 TEA20
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
