Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
G705 diesel miss at high idle
Post new topic    Yesterday's Tractors Forum Index -> Minneapolis Moline
jimvw
PostPosted: Mon Aug 13, 2012 3:04 pm    Post subject: G705 diesel miss at high idle Reply to specific post Reply with quote
Fired up the old Massey 97 with the 504 engine. Runs and accelerates good, but misses at high idle. Any ideas Unfortunatley I cannot drive the tractor yet as it needs a bull pinion on one side.
Alan K
PostPosted: Mon Aug 13, 2012 4:43 pm    Post subject: Re: G705 diesel miss at high idle Reply to specific post Reply with quote
If that has a Rosa-Master DB pump it may be the flex ring on the governor. Could also be the injectors.
dieselbob
PostPosted: Mon Aug 13, 2012 6:31 pm    Post subject: Re: G705 diesel miss at high idle Reply to specific post Reply with quote
check your static timing also you could check your advance if it is a DB pump but you need the clear timing window to do that Bob
BenAlbert
PostPosted: Tue Aug 14, 2012 5:52 am    Post subject: Re: G705 diesel miss at high idle Reply to specific post Reply with quote
If it runs good otherwise and isn't popping smoke then most likely your timing is a little bit slow. The original pumps on these don't have timing advance. I have a 707 that does this. It turns about 2200 at high idle and has a definate skip to it. As soon as it loads up a bit it goes away. You can advance the timing, but if you go too far it won't start very well.
mightymolinekid
PostPosted: Tue Aug 14, 2012 5:53 am    Post subject: Re: G705 diesel miss at high idle Reply to specific post Reply with quote
First of all, is it warmed up good when you do this? If not, there's your problem. Those energy cells need to be good and hot to work efficiently. If you've had it apart and just put it back together, check your timing, you may need a couple more degrees advance, which is where I would start. Loosen the pump and give it some and see if that helps. If its all original, could just be valve adjustment or an injector issue. I would run a couple bottles of Lucas injector cleaner through it. Don't follow the directions, use one quart to 5 or 10 gallons of fuel, that should help.
Captainhookerus
PostPosted: Tue Aug 14, 2012 2:28 pm    Post subject: Re: G705 diesel miss at high idle Reply to specific post Reply with quote
Sounds as if nozzle spindles may be hanging a little. Remove self locking nuts if so equipped, lockwashers if they are there and tighten plain nuts evenly to 15 ftlbs
Post new topic    Yesterday's Tractors Forum Index -> Minneapolis Moline All times are GMT - 8 Hours
