Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
335 fun pull?
Post new topic    Yesterday's Tractors Forum Index -> Minneapolis Moline
Stephsoliver
PostPosted: Thu Aug 16, 2012 12:02 pm    Post subject: 335 fun pull? Reply to specific post Reply with quote
I am thinking about taking my Bone stock MM 335 RC to a fun pull this weekend. My question is if pulling should i use the T/A or direct drive. I would hate to damage the T/A. Also should i add a little fluid to the rear tires. Thanks in advance
MM diesel
PostPosted: Thu Aug 16, 2012 1:03 pm    Post subject: Re: 335 fun pull? Reply to specific post Reply with quote
The T/A should be fine. I would not add fluid to the rear tires. I assume you drive across a scale before the pull. It might be tough to get rid of the weight of fluid in the tires.
Stephsoliver
PostPosted: Thu Aug 16, 2012 1:15 pm    Post subject: Re: 335 fun pull? Reply to specific post Reply with quote
This is not a sanctioned pull. I have never pulled before. And this would be my first pull/show. I talked to the man in charge and he said just bring your tractor and as long as it has a hitch to hook the chain to you can pull. I don't know what the rules are. I was thinking Second gear and then when it starts to power out engage the T/A. With the 38" rear tires it is high geared so maybe 1st gear direct drive.
R.D.F.
PostPosted: Thu Aug 16, 2012 1:36 pm    Post subject: Re: 335 fun pull? Reply to specific post Reply with quote
With a tractor like yours I would start in 1st gear, if everything hooks up right you will probably still pull the A/T lever down, have fun, let us know how it goes, Dale
Doug Cotton
PostPosted: Thu Aug 16, 2012 2:01 pm    Post subject: Re: 335 fun pull? Reply to specific post Reply with quote
I pull a 335 and use the T/A when I pull. Just make sure you let the tractor run for a while before pulling and leave the torque lever ahead to let it warm up. If you don't, when you pull it back it is like pulling a hand clutch back. Complete stop.....
Stephsoliver
PostPosted: Thu Aug 16, 2012 2:19 pm    Post subject: Re: 335 fun pull? Reply to specific post Reply with quote
Since this will be my first pull i am just praying i can show up a JD or two.
Stephsoliver
PostPosted: Thu Aug 16, 2012 3:22 pm    Post subject: Re: 335 fun pull? Reply to specific post Reply with quote
Doug Got any tips for a few extra Ponies. Like advance timing, adjust valves, carb, tire pressure ETC.... My engine is stock standard bore. The only thing i do know is the heads are the higher compression heads. When i looked up the head# they were 8:1.1 . I would like to do any thing i can do get a couple extra HP.
Doug Cotton
PostPosted: Fri Aug 17, 2012 3:25 am    Post subject: Re: 335 fun pull? Reply to specific post Reply with quote
Yeah, I've HEARD the crankshaft from a 445 will fit in the place of your crankshaft. That would take it from 165 to 206 cubic inches.
mightymolinekid
PostPosted: Fri Aug 17, 2012 7:03 am    Post subject: Re: 335 fun pull? Reply to specific post Reply with quote
LMAO at Doug! It's funny how many guys have "HEARD" what parts will swap and how to do it. I've "HEARD" those kind of things too. I don't know much about gassers, but I would advance the timing just a hair and if it knocks, I'd switch to premium gas, just for the pull. As for the tires, I've heard what most guys do is air the rear tires up so the psi is the same as the first number in the size. i.e. a 15.5/38 tire, run 15 psi (I personally don't do it that way) Don't put fluid in them, you want to get in the lightest weight class you can. I've HEARD of guys jimmy-ing the governor so you get more rpm, do that too. Most importantly....go and have fun!! Way too many people take tractor pulling waaaay to serious. Walk around, look at the other tractors, talk to lots of people, take a bunch of pictures and learn what you can. If you can, get there plenty early,and if he has time, talk to the sled operator before the pull. Tell him you're new and if he has any advice. A GOOD sled man will give you pointers on what to watch for and maybe who to talk to specifically.
Post new topic    Yesterday's Tractors Forum Index -> Minneapolis Moline All times are GMT - 8 Hours
