Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
Sheared keyway on Briggs
Post new topic    Yesterday's Tractors Forum Index -> Garden Tractors
Pacerman
PostPosted: Sat Aug 18, 2012 5:17 pm    Post subject: Sheared keyway on Briggs Reply to specific post Reply with quote
Please help Any ideas.. Have 21 HP single cylinder briggs keeps shearing keyway installed on Deere 126 mower with 125 hours. Have replaced key way hardened key runs fine for short period. Alum key shears quickly. Please share ideas where do I check. Has any one had problems with this engine?
Thanks for all replys!!!!
504
PostPosted: Sat Aug 18, 2012 7:56 pm    Post subject: Re: Sheared keyway on Briggs Reply to specific post Reply with quote
Are you missing the special washer, or have it upside down on the flywheel. Put it the right key or you will destroy the crankshaft or the flywheel. Be sure to torque the nut too.
RPM1941
PostPosted: Sun Aug 19, 2012 7:50 am    Post subject: Re: Sheared keyway on Briggs Reply to specific post Reply with quote
B & S engines use the soft key only for the timing, the taper drives the flywheel, must be torgued with impact tool, hard to achieve without.
joe csuti
PostPosted: Sun Aug 19, 2012 12:59 pm    Post subject: Re: Sheared keyway on Briggs Reply to specific post Reply with quote
Also check/remove any galled alum buildup from flywheel keys on crank & flywheel tapers,alum will prevent flywheel from sitting straight on crank taper & flywheel will not goto bottom of taper when flywheel nut tightend,causeing key to shear in a short time.
rustyj14
PostPosted: Sun Aug 19, 2012 4:40 pm    Post subject: Re: Sheared keyway on Briggs Reply to specific post Reply with quote
Be of the utmost care when tightening the nut that holds the flywheel on. You could shear off the threaded end of the crank-shaft, which would require a new craank-shaft! Best to tighten it by hand--forget the air or electric impact wrench!! BT/ST
Steel keys are not recommended in that application. Better check for what is causing the problems. rj
