ZB govenor
M5 Jack
PostPosted: Sat Aug 18, 2012 5:59 pm    Post subject: ZB govenor Reply to specific post Reply with quote
We have just bought a ZB for 1st gear tractor pulling.Govenor internal rod has oblonged the whole in casting arm and is twisting . It was rubbing on the side of housing.We get different results every time we try it and none of them good. We ground off some of the rod so it would not rub.When we put it on a pull it falls flat on its face.Linkage is new ,adjustable and free. Are there any NOS ones available or good rebuilders in central Il. My humor is now gone.
thanks.
Ill John
PostPosted: Sat Aug 18, 2012 6:07 pm    Post subject: Re: ZB govenor Reply to specific post Reply with quote
Motec Engineering, link is on the minneapolis-moline site under parts suppiers
M 5 Jack
PostPosted: Sat Aug 18, 2012 6:40 pm    Post subject: Re: ZB govenor Reply to specific post Reply with quote
Thanks,we had no luck at Danvers pull today with ZB,UB,or UB Special but M5 won so we did not get skunked.
MMDEL
PostPosted: Mon Aug 20, 2012 7:00 am    Post subject: Re: ZB govenor Reply to specific post Reply with quote
If the hole is oversized in the short arm inside the gov. housing you are loosing all of your gov action. There dare not be any slop in this area.
MMDEL
M 5 Jack
PostPosted: Tue Aug 21, 2012 6:57 pm    Post subject: Re: ZB govenor Reply to specific post Reply with quote
Thanks guys I sent it to Motec today.It was like it knew we where on the track.Messed up every time.At home hooked up to our 1 ton with 6x6 beam
under DMI hitch it would pull like a bear and bobble front end and dig to china with 14.9x 38
tires.The high compression head sure made it come alive.
ihman73
PostPosted: Tue Aug 21, 2012 9:43 pm    Post subject: Re: ZB govenor Reply to specific post Reply with quote
Yeah I have ZB governor...well 2 actually to work on when they make it to the top of the to do list.
Post new topic    Yesterday's Tractors Forum Index -> Minneapolis Moline All times are GMT - 8 Hours
