| Author |
Message |
55 50 Ron Long Time User
Posted: Sat Aug 18, 2012 6:02 pm Post subject: POR 15 |
Has anyone used POR 15? Did you like it? I just used some on my old Chevy truck. Hope it works. |
| Back to top |
sflem849 Tractor Guru
Joined: 15 Jan 2007 Posts: 5352 Location: SE Wisconsin
Posted: Sun Aug 19, 2012 4:41 am Post subject: Re: POR 15 |
Where did you get yours? There used to be a rival product that was sold at the local tractor show, but I haven't seen it available off the shelf. |
| Back to top |
Posted: Sun Aug 19, 2012 5:10 am Post subject: Re: POR 15 |
Eastwood.
The local Auto Value has the same product but with a
different name, at least that's what the sales clerk
said. |
| Back to top |
WI Dave Regular
Posted: Mon Aug 20, 2012 5:52 am Post subject: Re: POR 15 |
A guy I work with has used it. He said it worked great. |
| Back to top |
Posted: Mon Aug 20, 2012 6:47 am Post subject: Re: POR 15 |
| WI Dave wrote: | | (quoted from post at 06:52:24 08/20/12) A guy I work with has used it. He said it worked great. |
Where did he get it?
No luck at the Baraboo show. Hopefully Rock River will have the vendor there. |
| Back to top |
1130Leo Regular
Posted: Mon Aug 20, 2012 12:09 pm Post subject: Re: POR 15 |
I"ve used it, it works great, one thing though, make sure you have done ALL your welding before applying it. If not, you will have to grind it off the area you wish to weld, You can not weld thru it. It"s harder than heck, however does work great. Oh, and if you get it on your skin, only time will eliminate it, you can not wash it off with anything. |
| Back to top |
J.Wondergem Tractor Expert
Joined: 05 Mar 2009 Posts: 2005 Location: Rockford, Mi
Posted: Tue Aug 21, 2012 5:43 am Post subject: Re: POR 15 |
I got mine from the body shop supply store where I buy my paint. |
| Back to top |
Bodyman Regular
Posted: Tue Aug 21, 2012 7:21 pm Post subject: Re: POR 15 |
I have been using it for a while now and you can count me on the LIKE....side. Doing a "56 Chevy restoration/reconstruction. Put the body on the rotissorie, had it blasted (underside and firewall) with fragmented glass, applied POR 15 and then undercoated. Looks great, very tough finish. Great Product.......... |
| Back to top |
GlenIdaho Tractor Expert
Posted: Wed Aug 22, 2012 9:26 am Post subject: Re: POR 15 |
I've used it too, it flows very nicely and gives a high gloss finish. The draw back is that it does not withstand UV and to topcoat it requires POR's special primer. |
| Back to top |
DWF Regular
Joined: 05 Mar 2009 Posts: 183 Location: NE Minnesota
Posted: Wed Aug 22, 2012 4:38 pm Post subject: Re: POR 15 |
I've bought it direct from the POR15 company and also from TP Tools in Ohio. I'm sure you can find them both on the Net.
DWF |
| Back to top |
WI Dave Regular
Posted: Wed Aug 22, 2012 6:58 pm Post subject: Re: POR 15 |
| sflem849 wrote: | (quoted from post at 15:47:26 08/20/12) | WI Dave wrote: | | (quoted from post at 06:52:24 08/20/12) A guy I work with has used it. He said it worked great. |
I'll ask him tomorrow, if I see him. |
| Back to top |
jdhbag Regular
Posted: Thu Aug 23, 2012 10:37 am Post subject: Re: POR 15 |
I have used it on 6 John Deere tractors and it has worked fine for me. Follow their instructions and you should do fine. If you get it on your skin it will usually wear off in about 4 days, on cloth it will be there forever. There is only two ways to remove it from metal, grind it or use POR15 stripper. You can brush it or spray it and it covers good. They recommend their Tie Coat primer but other primers will work fine. Their web site is www.por15.com. |
| Back to top |
WI Dave Regular
Posted: Sat Sep 01, 2012 8:16 am Post subject: Re: POR 15 |
He got his from E-bay. My local auto paint store has it. $50 for a quart! |
| Back to top |
Posted: Sat Sep 01, 2012 11:22 am Post subject: Re: POR 15 |
They didn't have it at Rock River Thresheree. Where do you go for a GOOD tractor swap meet anymore. I don't care if its Baraboo, Sycamore, RR, or where it is mostly yard sale garbage. A guy can't go to a show and buy new and used tractor related parts anymore. |
| Back to top |
