Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
Build a Stutgard Za
Post new topic    Yesterday's Tractors Forum Index -> Minneapolis Moline
roadcomm
PostPosted: Sun Aug 19, 2012 6:01 am    Post subject: Build a Stutgard Za Reply to specific post Reply with quote
I am considering building an articulated Za simular to a Stutgard . Does anyone have any input on how to transfer power from the power unit to the rear end?
t.r.k.
PostPosted: Sun Aug 19, 2012 10:47 am    Post subject: Re: Build a Stutgard Za Reply to specific post Reply with quote
On the one I saw in Ohio once they used a timing belt between the power unit and the clutch shaft on the front transmission. Had a hole cut in the top of the bell housing for the belt to run through.
roadcomm
PostPosted: Sun Aug 19, 2012 6:08 pm    Post subject: Re: Build a Stutgard Za Reply to specific post Reply with quote
where do you get the power connected from the front half? I would probably use a chain drive jack shaft and u-joint
Kevin Moschenrose
PostPosted: Sun Aug 19, 2012 9:45 pm    Post subject: Re: Build a Stutgard Za Reply to specific post Reply with quote
Mr. Martin in PA. built one he has had out at the shows.
t.r.k.
PostPosted: Mon Aug 20, 2012 6:14 pm    Post subject: Re: Build a Stutgard Za Reply to specific post Reply with quote
The drive to the rear transmission was through a large tube coupler that also served as the pivot point between the two transmissions. I would presume it contained a short shaft and two Universal joints between the clutch shafts of the transmissions.
The gear shift on the rear transmission had been extended and the operator could probably shift it by reaching out the rear cab window. For most driving you probably only use the front transmission and only shift the rear one into gear when you really want to pull something.
roadcomm
PostPosted: Mon Aug 20, 2012 6:57 pm    Post subject: Re: Build a Stutgard Za Reply to specific post Reply with quote
thanks I understand how to hook rear through the clutch input shaft But I am not shure where to get the power output from the front, pto would run to slow
BMG1
PostPosted: Wed Aug 22, 2012 1:24 pm    Post subject: Re: Build a Stutgard Za Reply to specific post Reply with quote
Just a thought here. Are you possibly thinking of orienting the trans/rearends the same direction? All the ones I've seen point the trans/rearends bellhousing to bellhousing and usually flip the front ring gear over to drive the opposite direction. Maybe I'm missing your point.
Post new topic    Yesterday's Tractors Forum Index -> Minneapolis Moline All times are GMT - 8 Hours
