| Author |
Message |
Nate926 New User
Posted: Sun Aug 19, 2012 11:12 am Post subject: Starter wont turn over and coil it getting hot. |
I have a farmall super A that I bought last week, tractor was running except the altinator wasn't working, two days ago I went to start it with the battery fully charged it turned over twice and then nothing. I got my test light out and I am getting power to the starter, and then I noticed the 12 to 6 volt ballast rister is smoking and the coil is hot. So I decided to rewire the entire tractor because it needed it wires were original and in bad shape plus I put a new built in resister coil on it,and wired the alternator up because the previous owner didn't have it wire right all. I used 10ga wire which is over kill but I wanted it to be right. Now I have power to the starter still and power and the lights switch but the tractor still won't turn over and the new coil is still getting hot. Please help if you know what it might be. I'm sure I wired it right I have check the wire chart over and over and I am getting power in all the right places. Thanks!! |
| Back to top |
old Tractor Guru
Joined: 12 Mar 2000 Posts: 50459 Location: Lake of the Ozarks area of MO
Posted: Sun Aug 19, 2012 11:40 am Post subject: Re: Starter wont turn over and coil it getting hot. |
A coil will in fact get pretty warm if the points are closed and the ignition is on and the engine is not running.
As for the starter can you turn the engine over by hand??? If not then the starter may be locked up in the flywheel which is very common and could well be your problem. Farmall's are well known to do that for some odd reason |
| Back to top |
JMOR Tractor Guru
Posted: Sun Aug 19, 2012 11:44 am Post subject: Re: Starter wont turn over and coil it getting hot. |
Adding to Old's comments, since the starter only needs big battery cable to its switch & a battery ground to operate, you can forget ALL the other wiring as far as being able to get starter to turn the engine. |
| Back to top |
El Toro Tractor Guru
Posted: Sun Aug 19, 2012 12:40 pm Post subject: Re: Starter wont turn over and coil it getting hot. |
Loosen the bolts on the starter and shake the starter to see if the bendix drive is stuck in the ring gear on your flywheel. If that doesn't help pull the starter and use a pinch bar to see if the engine can be rotated. Hal |
| Back to top |
Jon Hagen Tractor Expert
Posted: Sun Aug 19, 2012 3:06 pm Post subject: Re: Starter wont turn over and coil it getting hot. |
Reall no reason to unbolt the starter to unjam it. Just put the tractor in the highest gear and push rearward on a rear tire. rock it to the rear until you see the radiator fan move, the starter will be loose. |
| Back to top |
Nate926 New User
Posted: Sun Aug 19, 2012 5:40 pm Post subject: Re: Starter wont turn over and coil it getting hot. |
Thanks guys alot for the information, took the starter out and it"s not working very good, I tested it once I got it off and it only works when I tap on the back so I am going to take it tomorrow and get it rebuilt |
| Back to top |
old Tractor Guru
Posted: Sun Aug 19, 2012 6:03 pm Post subject: Re: Starter wont turn over and coil it getting hot. |
I have found many times that only works once in a while. Unbolting works 100%^ of the time |
| Back to top |
old Tractor Guru
Posted: Sun Aug 19, 2012 6:04 pm Post subject: Re: Starter wont turn over and coil it getting hot. |
Tapping on it says it has bad brushes in it so yep replace or rebuild |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
