| Author |
Message |
jamienky New User
Posted: Tue Aug 21, 2012 8:17 am Post subject: john deere F915 |
PTO lever wont stay engaged !! have too keep your hand on it all the time!! any ideas? |
| Back to top |
rrobert Regular
Posted: Tue Aug 21, 2012 8:46 am Post subject: Either a spring is missing |
Or a bushing/bolt for the pivot is worn out. Check the idler arm too.
Not familiar with the F915 just generally speaking on engagement levers.
Usually, after you push the lever past a certain point, it is supposed to "snap" to hold it in place. |
| Back to top |
t1 Regular
Posted: Tue Aug 21, 2012 10:10 am Post subject: Re: john deere F915 |
Deere uses an electromagnet to hold it engaged. Something in the safety circuit could be preventing the magnet from being powered and holding the handle, or the magnet itself can be bad. |
| Back to top |
gtractorfan Long Time User
Joined: 26 Sep 2011 Posts: 1173 Location: Van Wert, Ohio
Posted: Tue Aug 21, 2012 12:28 pm Post subject: Re: john deere F915 |
My dad had one with the same problem. His low tech way of "fixing" it was to make a wood wedge to put inbetween the lever and the hole and use the piece in while it was running. |
| Back to top |
504 Tractor Expert
Posted: Tue Aug 21, 2012 5:52 pm Post subject: Re: john deere F915 |
Deere uses an electromagnet to hold it engaged. Something in the safety circuit could be preventing the magnet from being powered and holding the handle, or the magnet itself can be bad. (Is correct) Right side under the seat, round flat thing is what holds it in gear. Look for electrical problems. |
| Back to top |
504 Tractor Expert
Posted: Tue Aug 21, 2012 5:54 pm Post subject: Re: john deere F915 |
I forgot--check the fuse first. |
| Back to top |
Jack in Michigan Regular
Posted: Tue Aug 28, 2012 3:46 pm Post subject: Re: john deere F915 |
I had the same problem a few years back when I first obtained my F915. The parking brake was slightly engaged and was preventing the pto from staying engaged. I made sure the brake was completely release and that solved my problem. Jack |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
