C Narrow Front on a B
Charlie175
PostPosted: Wed Aug 22, 2012 9:31 am    Post subject: C Narrow Front on a B Reply to specific post Reply with quote
I was wanting to put a narrow front on my B for something different. What will be my parts list to do this?
RegulaRog
PostPosted: Wed Aug 22, 2012 10:09 am    Post subject: Re: C Narrow Front on a B Reply to specific post Reply with quote
What's so different? All Farmall B's were either tricycle or single fronts.
RegulaRog
PostPosted: Wed Aug 22, 2012 10:11 am    Post subject: Re: C Narrow Front on a B Reply to specific post Reply with quote
My bad, I was thinking farmall instead of Allis. Sorry
ralph1111
PostPosted: Wed Aug 22, 2012 11:43 am    Post subject: Re: C Narrow Front on a B Reply to specific post Reply with quote
You will need complete pedestal with gears, drag link and plate that sets between pedestal and raditor also steering arms both ends.
your wheel hubs will work and your steering gear box will also work just install arm 18o degrees from b setting.
If you want to move forward with the project I have all the parts to do the change over.
RALPH IN iowa
old
PostPosted: Wed Aug 22, 2012 11:50 am    Post subject: Re: C Narrow Front on a B Reply to specific post Reply with quote
Where you at??? I have all the stuff laying around to do that and might even trade you parts for parts so I could go with a wide front on my C
Dick L
PostPosted: Wed Aug 22, 2012 1:10 pm    Post subject: Re: C Narrow Front on a B Reply to specific post Reply with quote
Actually you can use your B steering box if you do it like I did.
steve(ill)
PostPosted: Wed Aug 22, 2012 1:44 pm    Post subject: Re: C Narrow Front on a B Reply to specific post Reply with quote
Dick, the front of the steering rod looks like the ball joint used on the C.. If you have the B bell crank on the back steering box, did you change the C steering rod to the B ball socket ?
ASEguy
PostPosted: Thu Aug 23, 2012 3:49 am    Post subject: Re: C Narrow Front on a B Reply to specific post Reply with quote
Wide fronts are hard to find. It took me over a year and some rock turning to find a wide front for my C which is actually an adjustable wide front off of a B. Pricey too.
Charlie175
PostPosted: Thu Aug 23, 2012 5:29 am    Post subject: Re: C Narrow Front on a B Reply to specific post Reply with quote
I'm in Virginia, however I have already located a C front pedestal with Arm that I am waiting on delivery.
I plan on keeping my wide in case I want to switch it back.
old
PostPosted: Thu Aug 23, 2012 7:43 am    Post subject: Re: C Narrow Front on a B Reply to specific post Reply with quote
Yep and in my area Bs also seem to be few and far between. In all the years I have been here I have only had 2 Bs come and go from the place and the first one my dad got in north Missouri back in the late 70s and hauled it down here to the farm
Dick L
PostPosted: Thu Aug 23, 2012 4:14 pm    Post subject: Re: C Narrow Front on a B Reply to specific post Reply with quote
I welded the end or a C arm to a B arm. I worked on the arm length as well as bringing out to where it would clear everything. Nothing difficult.
