Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
valve adj
Post new topic    Yesterday's Tractors Forum Index -> Harry Ferguson
one mf35 z134
PostPosted: Wed Aug 22, 2012 3:05 pm    Post subject: valve adj Reply to specific post Reply with quote
what is the right way to adjust the valves cold ?
PackardV8
PostPosted: Wed Aug 22, 2012 6:15 pm    Post subject: Re: valve adj Reply to specific post Reply with quote
Set distributor rotor ready to fire #1. Adjust #1 exhaust and intake. Repest process for 2,3 and 4 cylinders.
Note that there is a faster way to do it using firing order but it can get a bit confusing.
miner09
PostPosted: Thu Aug 23, 2012 4:31 am    Post subject: Re: valve adj Reply to specific post Reply with quote
As the motor turns over and the intake valve goes to the bottom just before it starts up adjust the exhaust valve. Do the same to adjust the intake as the exhaust in on bottom. Do each cylinder the same. I do all exhaust then all intake. Mark each as you set.Makes no difference which ones are first. You may have to turn motor over several time to make sure each valve is on bottom.
rustred
PostPosted: Thu Aug 23, 2012 6:53 am    Post subject: Re: valve adj Reply to specific post Reply with quote
get #1 cyl. at tdc on compression. you do this by watching the valves on its running mate, which is #4 cyl. when one closes and the other one starts to open thats when you stop rotating the engine.#1 is on tdc on compression now. this is called valves on the rock. cause you just rock the engine a bit each way and the valves do the same. then when # 1 cyl. is set you just follow the firing order for the adjust ment. 1 3 4 2 in that order.
1 3
4 2 are the running mates for 1 and 3 cyl's
* for cold adjustment you need to add a couple thou. to the hot spec.
and this is the proper way to adjust valves.
2tractors
PostPosted: Fri Aug 24, 2012 5:19 am    Post subject: Re: valve adj Reply to specific post Reply with quote
The valves run from either end as follows:-
ex-in-in-ex ex-in-in-ex. The setting of the valves is .010" inlet and .012" exhaust and they should be done cold...check them again when the engine has reached working temperature as they will close up slightly and should not be rattling at all, if they do you will probably find that the rocker that is rattling is worn where it rubs on the valve stem, really it should be ground to remove the wear and that will quieten it down. Just in case you don't know (sorry if you do) you set no.1 with No 8 open/No 2 with No 7 open and so on.....John....fergusontractors @ tiscali.co.uk
2tractors
PostPosted: Fri Aug 24, 2012 5:21 am    Post subject: Re: valve adj Reply to specific post Reply with quote
I found this in the archives and it's sir Johns method, works great.
