| Author |
Message |
john cutts Guest
Posted: Wed Aug 22, 2012 6:18 pm Post subject: 300 international |
Tractor runs about 10 to 15 minutes then dies. Any suggestions. |
| Back to top |
old Tractor Guru
Joined: 12 Mar 2000 Posts: 50398 Location: Lake of the Ozarks area of MO
Posted: Wed Aug 22, 2012 8:18 pm Post subject: Re: 300 international |
Well first off a lot more info from you. 6 or 12 volts??? What have or have you not done to it. Did it just start doing this or has it been a problem for a long time. Lack of info makes it hard for us to help you help your self. First thing tor do is check spark. Has to be a blue/white and jump a 1/4 inch gap or more. Next pull the carb drain plug and let it flow for a few minutes, catch the gas to make sure it does not have dirt/water/rust in it then post back what you find |
| Back to top |
Jon Hagen Tractor Expert
Posted: Wed Aug 22, 2012 8:20 pm Post subject: Re: 300 international |
When it quits, immediatly determine if it has a healthy spark at the plugs.
No or poor spark = ignition problems
good spark,= likely fuel supply problems.
Remove the plug in the bottom of the carb and see if you have a strong continuous fuel flow. |
| Back to top |
john cutts Guest
Posted: Sun Aug 26, 2012 7:54 am Post subject: Re: 300 international |
Thanks to all for info. I am a novice mechanic. A friend came by and found the problem right off. Gas was coming out of one side of gas flow tube from tank. Cleaned out
and runs fine. Just wasn't getting enough gas. I'll know better the next time. |
| Back to top |
showcrop Tractor Guru
Posted: Sun Aug 26, 2012 4:07 pm Post subject: Re: 300 international |
| john cutts wrote: | (quoted from post at 08:54:05 08/26/12) Thanks to all for info. I am a novice mechanic. A friend came by and found the problem right off. Gas was coming out of one side of gas flow tube from tank. Cleaned out
Just for future discussion that "gas flow tube from tank" is called the fuel line. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
