| Author |
Message |
Matt30 New User
Posted: Thu Aug 23, 2012 3:31 pm Post subject: Farmall super m won't drive |
My farmall super m won"t drive. We had a tractor pull and then during the pull the tractor got pulled, while in gear, and the tires stopped moving like it was in neutral. After I toke the tractor out of gear and back into gear and nothing happened. I am not sure if the clutch just gave out or what. Any help please?
Matt30 |
| Back to top |
rrlund Tractor Guru
Posted: Thu Aug 23, 2012 3:51 pm Post subject: Re: Farmall super m won't drive |
A little more info please. Was there a pop or a bang? Did it act like the clutch was slipping for a second or two? |
| Back to top |
old Tractor Guru
Joined: 12 Mar 2000 Posts: 50428 Location: Lake of the Ozarks area of MO
Posted: Thu Aug 23, 2012 4:03 pm Post subject: Re: Farmall super m won't drive |
With the lack of info hard to help you help your self.
Does the PTO still work??
If you jack it up and put it in gear will one tire spin forward and the other back wards. by hand that is??
With as little as you said it could be the clutch the input shaft and or the ring and pinion or for that matter a completely blown transmission |
| Back to top |
Matt30 New User
Posted: Thu Aug 23, 2012 5:01 pm Post subject: Re: Farmall super m won't drive |
I haven't tried any of that but I will have too and get back to you. Would it help to know if the belt works also? |
| Back to top |
Matt30 New User
Posted: Thu Aug 23, 2012 5:11 pm Post subject: Re: Farmall super m won't drive |
There was a pop, bang or some kind of noise when it happened and the tractor just stopped. |
| Back to top |
Matt30 New User
Posted: Thu Aug 23, 2012 5:12 pm Post subject: Re: Farmall super m won't drive |
There was no slipping. Something made a noise and it stopped |
| Back to top |
d beatty Guest
Posted: Thu Aug 23, 2012 5:57 pm Post subject: Re: Farmall super m won't drive |
You might have twisted the center out of the drive disc. |
| Back to top |
Matt30 New User
Posted: Thu Aug 23, 2012 6:12 pm Post subject: Re: Farmall super m won't drive |
That might be because when it is in gear it sounds like something is spinning and scratching just behind the flywheel. |
| Back to top |
old Tractor Guru
Posted: Fri Aug 24, 2012 7:45 am Post subject: Re: Farmall super m won't drive |
If it has the flat belt pulley yes since the Super M does not have live PTO/belt pulley |
| Back to top |
Ol' Gimpy Regular
Posted: Fri Aug 24, 2012 2:59 pm Post subject: Re: Farmall super m won't drive |
d beatty gets my vote.Seen Mack B-61"s with single disk clutches,and one of my Dodge pickups do the same thing,snap the hub out of the clutch disk.Have to admit I"ve never heard of any Farmall of that vintage do that,but always a first time- |
| Back to top |
showcrop Tractor Guru
Posted: Sat Aug 25, 2012 3:19 am Post subject: Re: Farmall super m won't drive |
I'm with DBeatty and Ol' Gimpy, I was driving a B-61 Mack once that had it happen just after I crested a hill and shifted up. |
| Back to top |
