DLTX-71 rusted carburator
CharlesTx
PostPosted: Fri Aug 24, 2012 5:06 pm    Post subject: DLTX-71 rusted carburator Reply to specific post Reply with quote
I;m trying to put some life into a 1947 model A. Carburator is a rusty mess on the inside. Choke value is stuck. Does a method exist to save the carb or should I just try to find a replacement?
greenmech
PostPosted: Fri Aug 24, 2012 7:44 pm    Post subject: Re: DLTX-71 rusted carburator Reply to specific post Reply with quote
Carb can be cleaned. All the brass plugs removed and the passages cleaned with proper size drill bits. Choke can be loosened up with PB Blaster. Or you can send it to a carburetor re builder. Ron Mn.
rustyfarmall
PostPosted: Sat Aug 25, 2012 5:51 am    Post subject: Re: DLTX-71 rusted carburator Reply to specific post Reply with quote
CharlesTX wrote:
(quoted from post at 18:06:59 08/24/12) I;m trying to put some life into a 1947 model A. Carburator is a rusty mess on the inside. Choke value is stuck. Does a method exist to save the carb or should I just try to find a replacement?
I've never worked on a JD carb, but they're made of cast iron, and cast iron can be heated up with a torch in the area of the stuck choke, and then spray some PB Blaster on it as it cools. When the carb is cool to your touch, grab that choke lever with a pair of pliers and begin GENTLY wiggling it back and forth, a little more PB Blaster, and before you know it that choke will be free, and then you can take it all apart. Screws, bolts, etc, and nearly anything else that is stubborn about moving will also benefit from the heat-er-up and cool-er-down philosophy.
Do NOT subject any parts made of aluminum or pot metal to the heat. A venturi made of aluminum or pot metal will just sort of disappear if you get it TOO hot.
Bead blasting will get rid of the rust.
ASEguy
PostPosted: Sun Aug 26, 2012 3:00 am    Post subject: Re: DLTX-71 rusted carburator Reply to specific post Reply with quote
My throttle valve was completely stuck on my 8N and I was faced with your dillema. I bought a gallon of carb cleaner from the auto parts store, disassembled it as best as I could an soaked it for two weeks. It cleaned up really nice and works well with a new kit and the throttle shaft freed up too. Patience is the key. Hope this helps. Gerard
Dodgeit
PostPosted: Mon Aug 27, 2012 11:59 am    Post subject: Re: DLTX-71 rusted carburator Reply to specific post Reply with quote
ASEguy wrote:
(quoted from post at 06:00:57 08/26/12) My throttle valve was completely stuck on my 8N and I was faced with your dillema. I bought a gallon of carb cleaner from the auto parts store, disassembled it as best as I could an soaked it for two weeks. It cleaned up really nice and works well with a new kit and the throttle shaft freed up too. Patience is the key. Hope this helps. Gerard
The dip type carb cleaner will not clean out stopped up passages in a JD 2 cyl. carb. Only a drill bit of the correct size will do it. Do your self a favor and send it to PopinJohn carb repair. (google is your friend) They'll do it right for cheap money compared to others.
The people who own this site also do the rebuilds.
36 Coupe
PostPosted: Sun Sep 02, 2012 2:07 am    Post subject: Re: DLTX-71 rusted carburator Reply to specific post Reply with quote
This is a very high priced carberator.The idle passages do plug up,Not a good carberator for amatures to mess with.
CharlesTx
PostPosted: Sun Sep 02, 2012 2:10 pm    Post subject: Re: DLTX-71 rusted carburator Reply to specific post Reply with quote
Thanks to all that replied. I have decided to send the carb off for a rebuild.
