| Author |
Message |
OldMoIron Regular
Posted: Wed Aug 29, 2012 6:35 pm Post subject: CA ignition re-do |
Can I get a Pertronix Ignitor for the 125ci Allis, or do they make them, thanks |
| Back to top |
Kip-Utah Long Time User
Posted: Thu Aug 30, 2012 9:22 am Post subject: Re: CA ignition re-do |
I assume that you are using a distributor & not a magneto...If so yes you use the same one for all early A-Cs with distributors. Kip |
| Back to top |
OldMoIron Regular
Posted: Thu Aug 30, 2012 10:46 am Post subject: Re: CA ignition re-do |
Thaks, Utah I contacted Oreilys they having hard time looking it up. I called Yesterdays tractors parts dept they had one in hand and its on the way. |
| Back to top |
Brian Jasper co. Ia Tractor Expert
Posted: Fri Aug 31, 2012 2:33 pm Post subject: Re: CA ignition re-do |
They are sensitive to the resistance of the primary side of the coil. It can't be lower than 3 ohms. If it is, you need to add a ballast resistor, or get a different coil. I have the Pertronix on my CA and their Flamethrower coil just to be sure they are compatible. I also run the plug gaps at .045. Made a big difference in idle and starting. |
| Back to top |
OldMoIron Regular
Posted: Fri Aug 31, 2012 3:25 pm Post subject: Re: CA ignition re-do |
what plugs and wires do use on it, thanks |
| Back to top |
Posted: Sat Sep 01, 2012 7:10 pm Post subject: Re: CA ignition re-do |
Either Autolite 303 or 295 plugs. I also prefer good copper wire core wires to the carbon core "resister" type wires. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
