| Author |
Message |
Fife Lake Fritz New User
Posted: Fri Aug 31, 2012 8:36 am Post subject: WD45 final drive gear pan gasket |
I went to change the leaking gasket on the final drive gear pan. I removed the gear oil thinking that I will have to turn the pan a certain way to remove it. But I have a nasty feeling that I will have to remove the whole tire to get it off.
The plan was, to make up one from cork gasket. Now I'm wondering if I could make a two part gasket and use some type of silicone gasket sealer to seal it.
Any thoughts or ideas greatly appreciated.
Old??? |
| Back to top |
Posted: Fri Aug 31, 2012 8:53 am Post subject: Re: WD45 final drive gear pan gasket |
OOPS I got it . Once I soaked up the remanding oil with rags. I played with it a bit and it just dropped out. Thanks anyways |
| Back to top |
Bob Bancroft Tractor Expert
Posted: Fri Aug 31, 2012 8:59 am Post subject: Re: WD45 final drive gear pan gasket |
After what I paid for OEM cork gaskets for a B several years ago- I think I would go over the pan with a little hammer on a flat surface- making sure the pan flange is true, and try silicone alone. |
| Back to top |
old Tractor Guru
Joined: 12 Mar 2000 Posts: 50449 Location: Lake of the Ozarks area of MO
Posted: Fri Aug 31, 2012 11:00 am Post subject: Re: WD45 final drive gear pan gasket |
The last one I did was on my C and I use silicone for the gasket instead of trying to make one or buy one. I did that probably 5 or so years ago and it has not leaked yet |
| Back to top |
Posted: Fri Aug 31, 2012 11:48 am Post subject: Re: WD45 final drive gear pan gasket |
I ended up using 1/32" FEL-Pro tan fiber sheet plus a thin bead of silicone on both sides for good measure.
I noticed in my manual that it mentions several times about using shelac as a sealeant on various parts, I wonder if silicone couldn't be used in those situations?
I eventually found some shellac at Home depot but it took awhile to find it.
Thanks again guy's |
| Back to top |
old Tractor Guru
Posted: Fri Aug 31, 2012 2:56 pm Post subject: Re: WD45 final drive gear pan gasket |
A little over a year ago I built a tractor out of 3 dead tractors and used only used gaskets and silicone to do all the gaskets including the head gasket. On the head gasket I use 6 coats of aluminum paint as the sealer and it has worked and ran just fine ever since. I used 2 Farmall Bs and an A to do it and I call it my BA |
| Back to top |
Orange fever New User
Posted: Fri Aug 31, 2012 4:56 pm Post subject: Re: WD45 final drive gear pan gasket |
Ive used black silicone RTV. It's thicker and works great. Put a nice bead on the pan, bolt it on, let it dry. You'll have great results. |
| Back to top |
old Tractor Guru
Posted: Fri Aug 31, 2012 6:16 pm Post subject: Re: WD45 final drive gear pan gasket |
On A/C tractors I use the red or orange stuff it blend in better and as long as the high heat stuff does as good as the black stuff but hides a whole lot better then the black LOL |
| Back to top |
Gary in da UP Regular
Posted: Tue Sep 04, 2012 6:49 pm Post subject: Re: WD45 final drive gear pan gasket |
Rick, are you fooling with the orange ones now?
Did you get the Powerwagon going? Gary |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
