| Author |
Message |
Awlknottedup Regular
Posted: Fri Aug 31, 2012 1:15 pm Post subject: Drilling holes in glass tile |
I need to drill some holes in glass tile. What is the preferred method? Hole size can be anywhere between 3/4 and 1 1/4. What about rough edges? |
| Back to top |
Tom in TN Tractor Expert
Joined: 05 Mar 2009 Posts: 1966 Location: Middle Tennessee
Posted: Fri Aug 31, 2012 1:19 pm Post subject: Re: Drilling holes in glass tile |
awl,
I've never used one, but Home Depot used to sell drill bits specifically for glass tile. If there's a Home Depot near you, you might check with someone in the flooring department.
Good luck,
Tom in TN |
| Back to top |
DON TX Tractor Expert
Joined: 09 Aug 2001 Posts: 2255 Location: Midlothian, Tx
Posted: Fri Aug 31, 2012 2:45 pm Post subject: Re: Drilling holes in glass tile |
Hardware stores and hobby shops have tile drills with spear tips to drill glass and ceramic tiles but may not be more than 1/4". For the size you want you will have to take to a glass shop or if the edge doesn't need to be nice you can drill a circle of holes to chip the larger hole out. HTH
DON TX |
| Back to top |
J_P Regular
Posted: Fri Aug 31, 2012 3:47 pm Post subject: Re: Drilling holes in glass tile |
I have drilled quite a few holes in glass block so my wife could make Christmas ornaments. I'd have to go out to the shop and look at the bit but the holes were big enough to stuff a string of Christmas tree lights through. If I remember correctly I got the bits at Menards. |
| Back to top |
jackbrit New User
Posted: Fri Aug 31, 2012 3:54 pm Post subject: Re: Drilling holes in glass tile |
drill press, copper pipe, grinding compound, clay wall around the area with a coolant? The spinning pipe is the bit and compound abrasive is the cutter. |
| Back to top |
Russ from MN Tractor Expert
Posted: Fri Aug 31, 2012 4:28 pm Post subject: Re: Drilling holes in glass tile |
Simmilar tojackbrit, I have glued down a piece of plywood with the same size hole, and then use a carbide hole saw with lots of water. Stop once in a while and use a wet shop vac and suck out the grindings and water. Go slow! |
| Back to top |
old_bc Regular
Posted: Fri Aug 31, 2012 8:57 pm Post subject: Re: Drilling holes in glass tile |
This may be your answer.
Drilling Glass
| Back to top |
cannonball Regular
Posted: Sat Sep 01, 2012 2:48 am Post subject: Re: Drilling holes in glass tile |
Untitled URL Link
| Back to top |
George Marsh Tractor Expert
Joined: 05 Aug 2009 Posts: 3104 Location: terre haute
Posted: Sat Sep 01, 2012 5:07 am Post subject: Re: Drilling holes in glass tile |
Go to ebay, buy it now. I purchased a small cheap set of 5 for around $15. Not as nice looking as the ones cannonball posted, but cheaper. If you need an individual diamond hole saw you can get them for around $3-4. I use my drill press and use a few drops of water to keep it cool.
I drill 1/2 inch holes in unusal glass bowls or cookie jars to make flower pots for the Boss. No ruff edges to speak of.
Drilled 1/2 inch holes in glass block to put Christmas lights inside block.
George |
| Back to top |
big fred Tractor Guru
Posted: Sat Sep 01, 2012 2:22 pm Post subject: Re: Drilling holes in glass tile |
Haven't tried in glass, but I use diamond coated hole saws for porcelain tile. Got em at Home DePot. Pricey, at about 10 bucks for the 5/16 diameter, but when you have the tile already set, you really, really, don't wanna break it. |
| Back to top |
Richard G. Long Time User
Posted: Sat Sep 01, 2012 4:42 pm Post subject: Re: Drilling holes in glass tile |
Yesterday my son called and said a huge plate glass window in the store his missionary office is renting had a crack growing up from the bottom. Saw this thread a little later and did some research.
He went to Lowes and picked up a glass bit for a Dremel tool. Followed instructions and drilled a 1/8 hole at the end of the crack. so far so good..
Thanks, Richard |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
