| Author |
Message |
dagger dog New User
Joined: 22 Jul 2009 Posts: 17 Location: Southern Indiana
Posted: Fri Aug 31, 2012 4:27 pm Post subject: HOW BIG ? |
I own a 1959 TO35 Deluxe. It's in better than good working condition, on a scale of poor,fair,good,very good, excellent.
To the question, how large of a bush hog would you use on it if it were yours ? The old tractor starts runs well, all the hydraulics (3pt) works as it should. I just don't want to overload the old boy.
I'm can weld, and am a decent enough wrench to keep stuff running.
What should I be on the look out for when I check out a used bush hog?
I want to reclaim some land that is over grown with Russian olive, 1" cedars, multi-flora rose etc .Would you think a larger 3pt finish mower to be too small ?
What say ye, great and knowledgeable Ferguson tractor gurus  |
| Back to top |
2tractors Long Time User
Posted: Fri Aug 31, 2012 5:03 pm Post subject: Re: HOW BIG ? |
6 FT. is about as big as you want to go and it will handle most heavy grass in first (high).The mower will stick out past the rear wheels a little but you can reverse the wheels by turning them inside out and swapping sides then let the front end out to match the back. It's not necessary but this way anything the front wheels clear then so will the mower. I also use a 6ft. finish mower. If your 59 is not a 2 stage then an override clutch should be attached to the PTO so the hog won't push you into something. |
| Back to top |
Boss Hog Long Time User
Posted: Sat Sep 01, 2012 4:34 am Post subject: Re: HOW BIG ? |
Seems to me a 5' mower is just about right. I've had a 6' mower on mine, but it was hard to keep the front end on the ground. |
| Back to top |
RalphL Regular
Posted: Sat Sep 01, 2012 8:19 am Post subject: Re: HOW BIG ? |
I agree with Boss Hog. I tried a six footer on mine and didn"t like the light front end. I would go with a five footer. |
| Back to top |
phil(va) Tractor Expert
Posted: Sat Sep 01, 2012 8:32 am Post subject: Re: HOW BIG ? |
A finish mower will be too light for what you want to cut. You will need a bush hog type. You probably could use a 6 footer, but as noted that will make the front very light and if you have hills or have to trailer it, that gets dicey. The safest choice is a 5 foot bush hog type. |
| Back to top |
Posted: Sat Sep 01, 2012 5:13 pm Post subject: Re: HOW BIG ? |
The light front end will make it steer like power steering. If it's dicy then put some weight on the front. If you want to spend all day cutting 5 acres then buy a lawn "tractor" more commonly known as a lawn mower.Just my 2 cents but I'm on flat ground. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
