Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
do u need tube in rear tire?
Post new topic    Yesterday's Tractors Forum Index -> Harry Ferguson
rusty nut
PostPosted: Sun Sep 02, 2012 7:55 am    Post subject: do u need tube in rear tire? Reply to specific post Reply with quote
got a flat rear tire,do u need tube for rear tire or can they b e tubeless?thanks,tires are loaded-but don"t think I want them loaded anymore-my personal thought is that causes more trouble than what it is worth(rusty rims around tire valve etc.thanks
trac
PostPosted: Sun Sep 02, 2012 9:44 am    Post subject: Re: do u need tube in rear tire? Reply to specific post Reply with quote
You don"t want tubeless i have two sets of rears i don"t like them if a stick gets jammed in the bead and rim it will leak do your self a favor and spend the money for tubes.
miner09
PostPosted: Sun Sep 02, 2012 9:46 am    Post subject: Re: do u need tube in rear tire? Reply to specific post Reply with quote
You can make them tubeless if rim is in good condition and tire OK. You can just break tire down at valve stem and cut stem off tube and put tubeless stem in and air it up. Just leave old tube in tire.Tube will not hurt anything inside with stem cut off. Or do all the work and remove tube.I've run several with old tube inside.
Tony in Mass.
PostPosted: Sun Sep 02, 2012 7:15 pm    Post subject: Re: do u need tube in rear tire? Reply to specific post Reply with quote
The way I always figured...was traction on the tire AND rim. The tubeless only grip the 2 together cause of airpressure sticking that tiny little flat part of the bead. The cleats ever get totally stuck, and the diff is giving it all its got, is only the air holding the bead from slipping, but with a tube, the entire inside surface of both is traction in a high torque situation. Whenever I have a lingering leak even on the daily driver, a tube goes in. End of slow leak...
phil(va)
PostPosted: Mon Sep 03, 2012 3:05 pm    Post subject: Re: do u need tube in rear tire? Reply to specific post Reply with quote
I run all tubes. Modern load in tube is methanol, not a rusting agent like CaCl. If you don't plow much or use it for heavy work no need for adding the load, plus it's easier to trailer when lighter, but if you need the traction put methanol in tubes. My two cents.
rusty nut
PostPosted: Tue Sep 04, 2012 3:47 pm    Post subject: Re: do u need tube in rear tire? Reply to specific post Reply with quote
thanks all,going to go with the tube,and keep them loaded,guy at work also said go with the tube and keep it loaded,I have loader on the front so I need the traction,thanks again.
