880 - 88 Frame
Eric Locstein
PostPosted: Sun Sep 02, 2012 11:59 am    Post subject: 880 - 88 Frame Reply to specific post Reply with quote
Hello Everyone......Is anyone able to inform if an Oliver 880 tub has a larger "tub" compared to Super 88??? Or are they the same??
Thank You
J. Schwiebert
PostPosted: Sun Sep 02, 2012 3:51 pm    Post subject: Re: 880 - 88 Frame Reply to specific post Reply with quote
Exactly what do you mean by larger? ? B. A. Star had a post on here abou changes in the frame once power steering became an option. What area were you wondering about?
Eric Locstein
PostPosted: Sun Sep 02, 2012 4:33 pm    Post subject: Re: 880 - 88 Frame Reply to specific post Reply with quote
I was curious about the inside room for a larger pan.....Thinking of repowering and would like to try to find out what frame gives us the most room Smile
jordan hackman
PostPosted: Sun Sep 02, 2012 5:43 pm    Post subject: Re: 880 - 88 Frame Reply to specific post Reply with quote
the 880 might be a tad bigger but if so it isn't much, and it would be longer not wider. also what do you mean by repower? and for power steering all you need to do is replace the front pedistal for one with a power steering system.
Sonar
PostPosted: Sun Sep 02, 2012 7:40 pm    Post subject: Re: 880 - 88 Frame Reply to specific post Reply with quote
I do know the 770/880 bellhousing will not fit in a 77 without some grinding, but unsure about the 88 tub.
OliverNate
PostPosted: Mon Sep 03, 2012 11:18 am    Post subject: Re: 880 - 88 Frame Reply to specific post Reply with quote
went out to the shed and did some measuring I have a '58 super 88 diesel and a '59 880 diesel w/ hydra-power and the tubs had the same measurements, same mounts on outsides, same hole for the oil pan on the underside
Eric Locstein
PostPosted: Mon Sep 03, 2012 11:24 am    Post subject: Re: 880 - 88 Frame Reply to specific post Reply with quote
Thank you everyone for your time.....Good to know this sort of thing, Winter is right around the corner and I am going to need something to screw around with......Curious what motor will actually fit in our Super 88 Smile
THANKS AGAIN!
G3400
PostPosted: Mon Sep 03, 2012 1:46 pm    Post subject: Re: 880 - 88 Frame Reply to specific post Reply with quote
I have a 451 Waukesha engine I was told will fit in the S88/880 frame with alittle work. Use your 88 bell and flywheel. 140hp @ 1900rmp. I'm trying to sell it if your interested give me a call or send an email. $1200.00 and runs great. 812-631-3863
billet-boy
PostPosted: Tue Sep 04, 2012 5:14 pm    Post subject: Re: 880 - 88 Frame Reply to specific post Reply with quote
Ok while we are on this subject, will a 88 standard rearend bolt up to 880 tub?
Eric Locstein
PostPosted: Tue Sep 04, 2012 6:47 pm    Post subject: Re: 880 - 88 Frame Reply to specific post Reply with quote
Hey..... G3400 ------ Keep that motor! Where are you from? Let's work something out :)
Im more than serious about this
G3400
PostPosted: Wed Sep 05, 2012 7:37 am    Post subject: Re: 880 - 88 Frame Reply to specific post Reply with quote
I'm in southwest indiana. It shouldnt be going anywhere. Not really an oliver guy other wise id be sticking it in an 880. I also have a 310 gas id consider selling but its not as cheap. give me a call sometime 812-631-3863
