| Author |
Message |
Todd from NC New User
Posted: Sun Sep 02, 2012 4:28 pm Post subject: new 12 volt conversion |
Converted my TO-20 over to 12 volts this weekend. Alternator appears to be a one wire. The problem, at least I think it is a problem, the amp meter is pegged over to +30 when the tractor is running. Seems to me, it should drop back to 1 or 2+. Battery is not completely charged but has plenty of juice. Battery shows 12-13 volts when off. With the tractor running it shows 14-15 volts. This would seem normal. Still think the alternator should drop back. |
| Back to top |
trac Long Time User
Posted: Mon Sep 03, 2012 4:09 am Post subject: Re: new 12 volt conversion |
So when you start it, it pegs out at 30+ then drops to 14 15 amps? If batt. is not fully charged it's gonna put out a lot of volts. Can't seem to remember were my one wire alt. runs on the ammeter but it must be normal I have a few other tractors with the 3 wire conversion and they will drop after running them awhile if that eases your mind any. |
| Back to top |
PackardV8 Regular
Posted: Mon Sep 03, 2012 6:29 am Post subject: Re: new 12 volt conversion |
Does it show 30 amps + even at a low idle speed???? |
| Back to top |
Jeremy in DE Regular
Posted: Mon Sep 03, 2012 7:58 am Post subject: Re: new 12 volt conversion |
I bought the 12 conversion kit from this website. It came with a one wire alternator. Try fully charging your battery and then see what happens. When my battery is fully charged it will start out at 30 amps and then drop down. But if not fully charged, it stays at 30 a long long time (presumably until fully charged?). |
| Back to top |
Posted: Tue Sep 04, 2012 9:10 am Post subject: Re: new 12 volt conversion |
Not much testing time the past few days - lot"s of rain.
Did notice at idle the amp meter went to 5+. Which I am taking as a good sign.
Also the alternator is a 63amp unit. So I suppose it is not outside the expectations that it would run at 30+ (on a 30 to 30 ammeter). |
| Back to top |
John(UK) Long Time User
Posted: Wed Sep 05, 2012 2:11 am Post subject: Re: new 12 volt conversion |
It will only drop right back if the battery is fully charged. Are you sure that it is wired correctly? Did you get the correct wiring diagram for this. You say you "think" it is 1 wire, you need to make sure and get the corresponding diagram to go with it. Unless your Alternator is faulty we get little trouble with them....John(UK)...fergusontractors@hotmail.com |
| Back to top |
Posted: Wed Sep 05, 2012 7:55 am Post subject: Re: new 12 volt conversion |
Yeah it dropped back to 5+ or so after a while. Maybe the battery is fully charged or nearly so. Wiring is correct. Had to check with the re-manufacturer on the one wire. The two other prongs are on the alt but under a plastic cap. The re-manufacturer said it was one wire. |
| Back to top |
Old School 55 New User
Posted: Wed Sep 26, 2012 8:55 am Post subject: Re: new 12 volt conversion |
My 1951 TO30 was converted to 12v but the points are shorting out? The coil is 12v and the distributor is a 6v, so I'm tring to drop the voltage to 6v from 12v to the points and can't find how many amps the distributor draws, which will tell Me how many volt reducer to use.Can anyone out there HELP ? |
| Back to top |
Bob (Aust) Tractor Expert
Joined: 06 Sep 2007 Posts: 2209 Location: Queensland, Australia
Posted: Wed Sep 26, 2012 11:23 am Post subject: Re: new 12 volt conversion |
| Quote: | | "The coil is 12v and the distributor is a 6v........" |
No your distributor is not "6 volts". A distributor is merely a form of switch. A distributor doesn't care what voltage (within reason) it switches. Don't drop your coil voltage if you have converted the tractor to 12 volts or you will defeat the purpose of the conversion.
Tell me about your "points shorting out"?
If they are burning out you likely have a faulty condensor. If they are "shorting out" the insulation between the points is breaking down and the tractor won't run. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
