1105 opinions.
steve terplak
PostPosted: Mon Sep 03, 2012 5:10 am    Post subject: 1105 opinions. Reply to specific post Reply with quote
There is an 1105 coming up in an auction soon. We've been looking to get a little more tillage power than the 1080. How is this tractor to use? Is it too big/too much for sm. sq baler/aybine? What is the price range to look for? We are in the northeast.
AllyCat
PostPosted: Mon Sep 03, 2012 10:26 am    Post subject: Re: 1105 opinions. Reply to specific post Reply with quote
These are a nice tractor. The only thing I don't care for is the parking brake. On a hill they can be hard to get out of park. Other than that they are a nice tractor and will be fine with any equipment as long as you use your head and not force any thing.As for what kind of shape it is in. 4000 to 7500 here in WI.
MikeinKy
PostPosted: Mon Sep 03, 2012 3:45 pm    Post subject: Re: 1105 opinions. Reply to specific post Reply with quote
I used to mow and bale hay and bush hog with my 1155.
steve terplak
PostPosted: Tue Sep 04, 2012 4:16 pm    Post subject: Re: 1105 opinions. Reply to specific post Reply with quote
Thanks for the replies.
I like my 1080 but find that it doesn't quite work like an 80 hp tractor...i know the 1100s had some issues with the rear end...
but i think the 1105 would probably be a good machine...like anything else, it depends on how it was treated in its past life.
BenAlbert
PostPosted: Tue Sep 04, 2012 4:53 pm    Post subject: Re: 1105 opinions. Reply to specific post Reply with quote
The 1105's were pretty decent tractors. The most common problem is with the hydraulics. The charge pumps tend to get weak with age. If you can run it make sure the steering works well at idle, if you have to rev it alot to turn the wheels, there could be problems. As said the park can be a pain. Pretty decent on fuel for its size. I used to use one on the baler all the time.
steve terplak
PostPosted: Tue Sep 04, 2012 5:53 pm    Post subject: Re: 1105 opinions. Reply to specific post Reply with quote
Thanks for the info, at this auction you can usually ride and drive if you et there early. So I'll definitely take a good look at the steering.
steve terplak
PostPosted: Tue Sep 04, 2012 6:08 pm    Post subject: Re: 1105 opinions. Reply to specific post Reply with quote
I noticed on tractor data.com that the 1105 has a 1000rpm pot...could it e converted to 540?
davediehl@hotmail.com
PostPosted: Tue Sep 04, 2012 7:54 pm    Post subject: Re: 1105 opinions. Reply to specific post Reply with quote
The 1105 is a good tractor. There is a sump in the bottom of the rear end with a screen to catch shavings and 'stuff'. It should be cleaned periodically and is really easy to do. It operates like your 1080 with only a few differences. The steering tilt lever is on the lower left side of the column. The PTO engagement lever is on the dash. And the manual unloading valve is new and under your right foot when seated. As someone said, the charge pump is a weakness. Check brakes, steering, multipower and hydraulics after its warmed up.
BenAlbert
PostPosted: Thu Sep 06, 2012 2:52 am    Post subject: Re: 1105 opinions. Reply to specific post Reply with quote
It should have a 2 speed pto. Four bolts and a different stub shaft is all it takes to change speeds. Not even any oil mess.
