| Author |
Message |
C.R. Long Time User
Joined: 05 Oct 2009 Posts: 1055 Location: south centeral wisconsin
Posted: Mon Sep 03, 2012 7:35 am Post subject: 1655 gear oil change |
I decided to replace the gear lube on the oliver this weekend I have been meaning to get this job done "for a wile" and I wanted to do it on a warm day Im glad I drained it the oil that came out looked like carmel sause real ugly! filled her up with ten gallons of fresh juice and should be good to go for a wile |
| Back to top |
J. Schwiebert Guest
Posted: Mon Sep 03, 2012 8:31 am Post subject: Re: 1655 gear oil change |
Change the filter as well? Also I don't remember the capacity but make sure the oil level is to the check plug or a little above if it is a little hilly where you are. |
| Back to top |
C.R. Long Time User
Posted: Tue Sep 04, 2012 1:31 am Post subject: Re: 1655 gear oil change |
is that the filter on the left side kind of up under the platform ? I need to do that again |
| Back to top |
pine forest Guest
Posted: Tue Sep 04, 2012 5:58 am Post subject: Re: 1655 gear oil change |
I have a 1755 diesel that I need to do this to. Where is the filler plug and the level plug? |
| Back to top |
OLarry from MD Regular
Posted: Tue Sep 04, 2012 8:38 am Post subject: Re: 1655 gear oil change |
Yes if the oil looks bad the filter is too. |
| Back to top |
C.R. Long Time User
Posted: Wed Sep 05, 2012 1:49 am Post subject: Re: 1655 gear oil change |
on my 1655 the filler is under the floor board there is a round plug that you have to pry up and under that is the filler for the gear oil the level is on the right rear of the axel housing it takes about ten gallons to fill |
| Back to top |
J. Schwiebert Guest
Posted: Wed Sep 05, 2012 4:26 pm Post subject: Re: 1655 gear oil change |
Your fill plug and the check plug are both in the back. Do you do any PTO work with the tractor or a grade ? The capacity is also more than on a 1655. I will need to look the capacity up as I have not filled one in at least 36 years.Your filter is on the left side like on the 1655. J. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
