| Author |
Message |
Dave Rodenberg New User
Posted: Mon Sep 03, 2012 3:35 pm Post subject: Allis B Governor |
What would cause the governor to pulsate on my 1948 B we just got it to run and thin governor started this pulsate revaing the motor up and down and up down i need help ! |
| Back to top |
Ted in NE-OH Guest
Posted: Mon Sep 03, 2012 3:52 pm Post subject: Re: Allis B Governor |
You need the anti surge spring that goes from the carb linkage to a manifold stud. Someone post a picture. |
| Back to top |
old Tractor Guru
Joined: 12 Mar 2000 Posts: 50454 Location: Lake of the Ozarks area of MO
Posted: Mon Sep 03, 2012 4:13 pm Post subject: Re: Allis B Governor |
There are a few things that will cause that to happen. Lack of that spring but then also a carb that is not working as it should causing it to run to lean and even a vacuum leak can cause it. If you can grab the carb/gov rod and hold it and smooth it out then could well be the spring but if that does not work and the engine dies then it is running to lean. If choking it also helps it is to lean |
| Back to top |
Posted: Mon Sep 03, 2012 4:22 pm Post subject: Re: Allis B Governor |
Thanks !!! |
| Back to top |
old Tractor Guru
Posted: Mon Sep 03, 2012 4:48 pm Post subject: Re: Allis B Governor |
Always happy to help if and when I can |
| Back to top |
Rod (NH) Tractor Expert
Joined: 18 Jan 2002 Posts: 2673 Location: SE New Hampshire
Posted: Mon Sep 03, 2012 5:13 pm Post subject: Re: Allis B Governor |
| Back to top |
steve(ill) Tractor Expert
Posted: Mon Sep 03, 2012 5:49 pm Post subject: Re: Allis B Governor |
surging is caused by a carburetor that is worn or not 100% adjusted correctly. The "surge spring" that Ted shows is the factory fix for the problem. |
| Back to top |
Dick L Tractor Guru
Posted: Tue Sep 04, 2012 6:14 am Post subject: Re: Allis B Governor |
I don't use the spring and do not have the problem. If it is more than a tad out of whack the spring will not do a thing.
Use the spring if you have one but it is not the fix all of surging.
A bunch of things can cause surging. When the fuel runs without restrictions, the gaskets are all sealing from the manifold to the throttle rod seal, to the cross over arm linkage adjustments, they will not surge with or without a spring.
No spring on this one. I have posted this old video many times to show what the little engines can do. If yours don't act like this one, it can when adjusted correctly. No magic.
Listen Close Here
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
