Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
WD45 oil pan gasket
Post new topic    Yesterday's Tractors Forum Index -> Allis Chalmers
Fife Lake Fritz
PostPosted: Thu Sep 06, 2012 3:34 pm    Post subject: WD45 oil pan gasket Reply to specific post Reply with quote
Does any one know what thickness the oil pan gaskets should be.
I prefer to make my own. I removed the pan and found the paper thin type on the sides. But the u shaped ones at the front and rear ends of the pan, appear to be a thicker cork.
Also while removing the bolts to the pan one broke off in the block with about a 1/4 inch of it exposed.
I plan on just applying penetrating oil for the next few days and tapping it lightly with a hammer before I try heating the area of the block
and removing it with vise grips.
I saw on the net once where the person used heat and parafin wax to remove seized bolts. Does any one know if this works?
David Inman
PostPosted: Thu Sep 06, 2012 5:26 pm    Post subject: Re: WD45 oil pan gasket Reply to specific post Reply with quote
I'm thinking that the alis pans with the CORK u are around a 1/4 of an inch thick new and appear slightly longer than needed--but crush to fit. Or is that the Allis pans that use the fiber ends. Or both. Personally, I'd spend the money on a oil pan gasket set, but hopefully some one can give you exacts, since that's the route you wish to go.
Ted in NE-OH
PostPosted: Thu Sep 06, 2012 5:36 pm    Post subject: Re: WD45 oil pan gasket Reply to specific post Reply with quote
I broke a pan bolt off on a B because I turned it the wrong way. I used an Easy-Out and it worked. That was the first time ever that an Easy-Out worked for me. Worth a try.
JMS/.MN
PostPosted: Thu Sep 06, 2012 7:10 pm    Post subject: Re: WD45 oil pan gasket Reply to specific post Reply with quote
I"m a firm believer in using candlewax- BTDT dozens of times. Apply the wax as the heated part cools, letting it melt into the threads. Can also try a left-handed drill bit if you drill them out. Cork side gaskets are maybe 1/8 inch thick, end gaskets are about a quarter inch thick.
PokeyOkie
PostPosted: Sun Sep 09, 2012 9:24 pm    Post subject: Re: WD45 oil pan gasket Reply to specific post Reply with quote
I bought a B a number or years ago and one of the oil pan bolts was broke off with none of the bolt exposed at all. I took my torch and very carefully melted the bolt out of the hole. The bolt will melt before the cast iron block. Used a tap to clean up the hole threads. But watch out for the melted metal...! Worked for me...
