Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
assembly of starter?
Post new topic    Yesterday's Tractors Forum Index -> Tool Talk
RalphWD45
PostPosted: Thu Sep 06, 2012 5:30 pm    Post subject: assembly of starter? Reply to specific post Reply with quote
I pulled a B Allis Chalmers starter apart, replaced the 4 brushes, cleaned the armature comuter, and now cant get the brushes to stay back so I can put the armature back in. How do you keep the brushes out of your way till you put the armature in?
LKM
PostPosted: Thu Sep 06, 2012 5:51 pm    Post subject: Re: assembly of starter? Reply to specific post Reply with quote
The brushes are held in contact with the commutator by spring tension. Use a heavy thread or small wire and tie the brush holder and brush back on at least 3 of the brushes while holding the forth back with a small hook type object. Slip the communator back into position and release the springs. I personally use baling wire to make small hooks and secure them to a bolt or any feasable place on the outside of the case.
Dalex
PostPosted: Thu Sep 06, 2012 6:42 pm    Post subject: Re: assembly of starter? Reply to specific post Reply with quote
Is it a Delco or an Autolite /Prestolite ?
thurlow
PostPosted: Thu Sep 06, 2012 6:53 pm    Post subject: Re: assembly of starter? Reply to specific post Reply with quote
Don't recall ever rebuilding an A-C starter, but on the ones I have rebuilt, I've balanced the starter on its other end, slide the outside down over it and hold the brushes back with 2 fingers on each hand.
old
PostPosted: Thu Sep 06, 2012 7:29 pm    Post subject: Re: assembly of starter? Reply to specific post Reply with quote
Not 100% sure on that one but most of them you can pull the brushes back to the point the spring hold the bushes up and out of the way but not so far as to have the springs drop back in. Then you still the armature in then one by one push the brushes down to the point the springs take over
MarkB_MI
PostPosted: Fri Sep 07, 2012 1:44 am    Post subject: Re: assembly of starter? Reply to specific post Reply with quote
Pull the springs out of the way so you can retract the brushes. Once a brush is halfway out of its holder, let go of its spring. The spring will push against the side of the brush and hold it in place while you assemble the starter. Then just pull the springs back again, slide in the brushes and return the springs to their proper locations.
Dusty MI
PostPosted: Fri Sep 07, 2012 3:38 am    Post subject: Re: assembly of starter? Reply to specific post Reply with quote
How's the bearings ? Most times they need replacing.
showcrop
PostPosted: Fri Sep 07, 2012 4:28 am    Post subject: Re: assembly of starter? Reply to specific post Reply with quote
I've done it with string.
pete 23
PostPosted: Fri Sep 07, 2012 9:47 am    Post subject: Re: assembly of starter? Reply to specific post Reply with quote
On delco's I always pull end plate first and install last with brush's on it and just work one brush at a time on to commutator. I say this because I have seen so many try to leave the end plate on and inset commutator through barrel into end plate. You may have a different starter but after you do a few hundred one always figures out a way to readily do it.
Mike (WA)
PostPosted: Mon Sep 10, 2012 2:30 pm    Post subject: Re: assembly of starter? Reply to specific post Reply with quote
Wife is a dental hygienist, so we always have a lot of dental floss hanging around. It is very strong, and not bulky like string. Tie brush up and out of the way, and stick an Xacto knife in to cut it when the time comes.
