| Author |
Message |
Fred from MO Long Time User
Posted: Fri Sep 07, 2012 6:58 am Post subject: Cutting torch flash arresters or not? |
How many of you use or have flash arrestors on an cutting torch set up? Are they really needed? Or is this one of those OSHA things because someone did something silly a long time ago and the government stepped in? Educate me please!! I would like your experiences to help guide me in purchasing these or not? |
| Back to top |
JMS/.MN Tractor Guru
Posted: Fri Sep 07, 2012 7:20 am Post subject: Re: Cutting torch flash arresters or not? |
Got mine before there was OSHA- just makes sense to lessen the chance of blowing the tank. Mine are on the torch- 50 feet from the tanks. |
| Back to top |
BDT in Minnesota Long Time User
Joined: 25 Feb 2006 Posts: 1048 Location: Erskine, Mn
Posted: Fri Sep 07, 2012 7:29 am Post subject: Re: Cutting torch flash arresters or not? |
Fred,, I would not own a torch without these updates..... A friend and neighbor had a torch set blow on him some time ago...spent his share of time in a burn unit..... not fun........ |
| Back to top |
AgmanWallistx New User
Posted: Fri Sep 07, 2012 8:51 am Post subject: Re: Cutting torch flash arresters or not? |
I taught H.S agriculture for many years and yes they are necessary. I would not use a torch without them. |
| Back to top |
Posted: Fri Sep 07, 2012 8:52 am Post subject: Re: Cutting torch flash arresters or not? |
Thanks thats enough responses for me to be a believer in them. |
| Back to top |
JOHNNYfromMI Regular
Posted: Fri Sep 07, 2012 8:58 am Post subject: Re: Cutting torch flash arresters or not? |
I lost all the skin on my right arm. Befor they were required. Use them!!! You never know they were there while operating the torch, but back feed a little gas into the high pressure side of the oxygen regulator and you have a hot problem. I know I've been there. |
| Back to top |
Rod in MN Regular
Posted: Fri Sep 07, 2012 10:50 am Post subject: Re: Cutting torch flash arresters or not? |
HI. USE them I spent 8 day"s in hostpitl with 80%of my back burend with 2 and 3rd deg. burnes out of work for 30 day"s. Had to were a special vest for 2 years to keep scars from raiseing up scares are all smooth now not fun
Rod in MN |
| Back to top |
Puddles Tractor Expert
Posted: Fri Sep 07, 2012 12:07 pm Post subject: Re: Cutting torch flash arresters or not? |
We went years without using them, then the safety department started having little hissy fits! Go ahead and use them, why not be safe? Once they are on the gauges or the torch, you'll never know they are there.
| Back to top |
Ken Macfarlane Tractor Expert
Posted: Fri Sep 07, 2012 12:42 pm Post subject: Re: Cutting torch flash arresters or not? |
They always have a display of blown up torches at the local welding shop hanging above the arrestors. More added every time I'm in there.
That said, I'm a bad guy and don't run them, propane runs such low pressure (I'm at 1-3 psi) it doesn't seem to mix back into the oxygen line. I should get a set on there though, they aren't gonna hurt anything. |
| Back to top |
RalphWD45 Long Time User
Posted: Fri Sep 07, 2012 2:35 pm Post subject: Re: Cutting torch flash arresters or not? |
I am 73, and been using a torch off and on , since adulthood. I have never heard of them, and probably still wouldn't know of them, if I hadn't read this post. They sound like good insurance to me! I use propane now days, except for welding. I will get those arrestors, for my torch, next time I pick up oxygen. |
| Back to top |
Dick L Tractor Guru
Posted: Fri Sep 07, 2012 3:54 pm Post subject: Re: Cutting torch flash arresters or not? |
Never heard of them until I bought a new torch set 35 years ago. The welding supply company told me they were a good idea and I had them put on the invoice. When OSHA came in it was the first thing they made a bee line for. At that time the fellow said it was unusal to find them on torch gages the first time in. |
| Back to top |
504 Tractor Expert
Posted: Fri Sep 07, 2012 5:43 pm Post subject: Re: Cutting torch flash arresters or not? |
Several of the new regulators have them built in now, good idea. |
| Back to top |
Bleeding Orange SW Iowa Regular
Posted: Fri Sep 07, 2012 6:05 pm Post subject: Re: Cutting torch flash arresters or not? |
I have them on both my oxygen/acetylene sets. I don't know about other types of gas torches. Cheap safety up front, versus expensive aftermath. Fortunately, I have no horror stories, just listened to an older, wiser man when he advised me to do it. Since then, no one has told me I wasted my money. I try to learn by others' mistakes when I have the opportunity, but I still make plenty of my own. |
| Back to top |
1950 MFD New User
Posted: Fri Sep 07, 2012 7:23 pm Post subject: Re: Cutting torch flash arresters or not? |
I thought they were an added expence untill I watched my brother-in-law blow one of they hoses off his torch. If his hoses weren't old and ready to be replaced anyway, we could have had alot bigger problems. |
| Back to top |
Keith Molden Long Time User
Joined: 05 Mar 2009 Posts: 774 Location: Pomeroy, Ohio (Meigs County)
Posted: Sat Sep 08, 2012 2:59 am Post subject: Re: Cutting torch flash arresters or not? |
You really should have them on both the torch and the regulators. Saves the hoses from burning back to the regulators then to the cylinders. We require them in both places at American Electric Power. Most new torches made by Victor and others now have them built in. Just my thoughts, Keith |
| Back to top |
