JD CCA field cultivator
wijim
PostPosted: Sat Sep 08, 2012 5:20 pm    Post subject: JD CCA field cultivator Reply to specific post Reply with quote
What size tire came on them new. And what size truck tire can replace them. Wheel size is 15x4.5 Thanks jim
AJB-830
PostPosted: Sun Sep 09, 2012 4:47 pm    Post subject: Re: JD CCA field cultivator Reply to specific post Reply with quote
Looks like my JD CC field cultivator has 6.70 x 15 tubeless car tires on it. They look to be the original tires as all the thread is still on them. My serial plate is stamped CC so not sure if this is the same as a CCA. I occasionally use it to work up the stuble in my wheat & oats fields and to excerise by JD 830. Al
Leroy
PostPosted: Sun Sep 09, 2012 5:26 pm    Post subject: Re: JD CCA field cultivator Reply to specific post Reply with quote
Smaller sizes normal was 6:70 used auto tires you provided of your car while larger sizes was 7:60 same way. Parts book will tell wheel width to total width. First was the CC with steel wheels, then the CC147 either way and 15" or 16", that the CC-A. Built from mid 30's to late 60's.
wijim
PostPosted: Sun Sep 09, 2012 6:20 pm    Post subject: Re: JD CCA field cultivator Reply to specific post Reply with quote
The tag on mine is CC A its a trip lift 12ft. I'll look for some used tires this week. Thanks all, Jim
Post new topic    Yesterday's Tractors Forum Index -> Implement Alley All times are GMT - 8 Hours
