| Author |
Message |
billy39 Guest
Posted: Sat Sep 08, 2012 6:51 pm Post subject: big cube diesels |
i saw some videos and posts about some big cube diesels i got a little derailed with the smack talk lol. but im toying with the idea. i do not have much experience with mm diesels but i am going to be dragging home my new project a gvi diesel in the next week or two. i have some parts collected i was planning on building a big short jug gas engine but the diesel could be fun. what do you guys think? |
| Back to top |
MMUBMM Guest
Posted: Sun Sep 09, 2012 3:40 am Post subject: Re: big cube diesels |
You will spend twice the money and get half the horsepower with a MM diesel. |
| Back to top |
mightymolinekid Regular
Posted: Sun Sep 09, 2012 5:16 am Post subject: Re: big cube diesels |
Yep there's going to be BS talk, but don't let it get you down. You will not spend twice as much for half the power of a gas engine. You will spend more for roughly the same power, though. The biggest expense over a gas is the fuel system. Expect a high performance pump and injector job for a 6 cylinder to cost around $2,500. All the other parts are the roughly the same stuff you'd buy for a gas. You will have tons of torque, and something different, which in my opinion is worth the extra trouble. One important thing to keep in mind is what classes you want to run. There are situations where a big cube gas engine is the way to go. A lot of guys absolutely can't stand MM diesels, and their reasons are somewhat justified, you just have to steer clear of them and find a MM diesel guy to talk to. I may know of a couple around....by the way...feel free to email me |
| Back to top |
billy39 Guest
Posted: Sun Sep 09, 2012 6:24 am Post subject: Re: big cube diesels |
i agree i like being diffrent too. just having a yellow tractor is diffrent around here to begin with. my email is open too. |
| Back to top |
mm585 Regular
Posted: Sun Sep 09, 2012 7:47 am Post subject: Re: big cube diesels |
There are many hard running gas molines around and they are the most bang for your buck,,,,But wouldent a MM diesel be fun to own??!! Go with what you want to build.dont let smack talk discourage you. |
| Back to top |
Posted: Sun Sep 09, 2012 12:44 pm Post subject: Re: big cube diesels |
Here's one in Ohio that runs div 5 with COATPA. The class limit is 530 cubes (I think) but he has a P pump and a 2.75" turbo.
| Back to top |
billy39 Guest
Posted: Sun Sep 09, 2012 1:52 pm Post subject: Re: big cube diesels |
thats cool. the only issue i have is it would have to be n/a or get put up in 11,000 lb class |
| Back to top |
pplowboy Guest
Posted: Sun Sep 09, 2012 3:14 pm Post subject: Re: big cube diesels |
I think minnie be fun.. u won before you ever hooked to the sled. Red or green jus another red one or green on in the crowd.crowds wamts see the odd ones. Or diffrrent ones. You gotta deside what class an clubs pull for..so to get pull.in areas you want to pull.all rule are not the same. None turbo be cool.. 6"crank. 4 13/16 pistons.. make tuff puller..but you could go bigger.. but then how much money. You want spend. Be nise a big minnie. But life of the block be comes a issue.. curiuos how big u think u need to be?? What kinda tractor you goin to pull against? In this n/a class |
| Back to top |
billy39 Guest
Posted: Sun Sep 09, 2012 5:33 pm Post subject: Re: big cube diesels |
im going to be setting it up to pull 7500 and 9500 enhanced farm. it is 2800 rpm limit no pace class non turbo unless factory stock. mostly 4010s run in it . i was planning on doing a 650 ish gasser. just thinking that keeping it diesel could be fun too |
| Back to top |
billy39 Guest
Posted: Sun Sep 09, 2012 5:46 pm Post subject: Re: big cube diesels |
my uncle has a big u also plowboy the gvi is my project . ive worked on the u a lot just never a minnie diesel |
| Back to top |
Dieselbear Long Time User
Posted: Sun Sep 09, 2012 6:28 pm Post subject: Re: big cube diesels |
Here"s a big cube natural asp. diesel for you
http://www.youtube.com/watch?v=cbXws2SyGyY |
| Back to top |
billy39 Guest
Posted: Mon Sep 10, 2012 4:47 am Post subject: Re: big cube diesels |
thats what im talkin about dieselbear. cool! |
| Back to top |
MMUBMM Guest
Posted: Mon Sep 10, 2012 6:09 am Post subject: Re: big cube diesels |
Bottom line: Gas or LP will be cheaper to build than a diesel and will have more horsepower. |
| Back to top |
mm585 Regular
Posted: Mon Sep 10, 2012 12:23 pm Post subject: Re: big cube diesels |
Everybody and there dog pulls a gas or lp tractor and there is nothing wrong with that, But a big cube moline diesel......well......YOU CANT PUT A PRICE ON COOL!!!!!!! |
| Back to top |
Molineone Regular
Posted: Mon Sep 10, 2012 1:02 pm Post subject: Re: big cube diesels |
Not everyone wants the same tractor that everyone else has. It doesn't work for everyone to just blend into the same boring herd. As long as it works for you I guess... |
| Back to top |
