| Author |
Message |
4020deereboy Long Time User
Posted: Sun Sep 09, 2012 1:28 am Post subject: Pto driven pump |
Is there any reason I can't charge a Pto pump with pressure from the tractor hydraulic pump or would I blow the pump seals? my muir hill only flows 6 gpm so I was thinking I'd use that oil to feed the Pto pump Any ideas ?
Thanks Shaun. |
| Back to top |
rufus80 Regular
Posted: Sun Sep 09, 2012 3:58 am Post subject: Re: Pto driven pump |
I wouldn't. Even the smallest pto pump Prince makes flows more that 6gpm, so your going to need more supply. Also most need a minimum of 1-1/4" suction line. There is also the possibility of ruining the pto pump if pressure is applied to the suction side. Rule of thumb is they require at minimum a resevoir the same size as your pump flows, 25 gallon tank for a pump that flows 25gpm. |
| Back to top |
Posted: Mon Sep 10, 2012 11:40 pm Post subject: Re: Pto driven pump |
Thanks for the reply I was just wondering if it would work I'm still thinking of using the tractor resivoir to supply the pump but I dont think it will work because they oil would have to go up hill to get to the pump. |
| Back to top |
ed3 Guest
Posted: Tue Sep 11, 2012 8:56 am Post subject: Re: Pto driven pump |
Save your self a lot of headaches and just buy a take.
You can also make one from a 5 gallon tank real cheep. plumming into the tractor is a pain in the A---. and you could screw up something.
Metal shavings don't mix well in hyd/trans fluid that lubs the trans and hydraulics |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
