Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
MF 165 PTO Clutch will not disengage
Post new topic    Yesterday's Tractors Forum Index -> Massey Harris & Massey Ferguson
gostate
PostPosted: Sun Sep 09, 2012 5:53 pm    Post subject: MF 165 PTO Clutch will not disengage Reply to specific post Reply with quote
The PTO on my cousins newly aquired MF 165 will not stop at all with the two stage clutch. Do not know tractor's history. What should we be looking at first?
DavidP, South Wales
PostPosted: Mon Sep 10, 2012 1:57 am    Post subject: Re: MF 165 PTO Clutch will not disengage Reply to specific post Reply with quote
Hello,
There are three main possibilities. First the plate may be stuck to the PTO flywheel through lack of use. If so, freeing will usually mean that the tractor will have to be split and the clutch unit stripped. Sometimes it is possible to insert a screwdriver between the plate and pressure plate or flywheel to free it. This is of course done from underneath through the inspection port.
Another possibility is poor adjustment. The gap at the 3 outside adjusters is nominally 090". This can vary due to wear in the unit as a whole.
This gap can be adjusted down to about 070" but don't go any less'
The third possibility is that the lining on one side of the plate has broken. A loose piece can be sandwiched between the plate and PTO flywheel
or PTO pressure plate. Although the pedal feels good there may not be enough movement to free it.
Have an assistant operate the clutch pedal whilst you check the operation using a flashlight. Check that all release levers are in contact with the release bearing and observe the amounts that the various components move at each press of the pedal.
At this time my money would be on a seized plate.
DavidP, South Wales
gostate
PostPosted: Fri Nov 16, 2012 5:15 pm    Post subject: Re: MF 165 PTO Clutch will not disengage Reply to specific post Reply with quote
We found out that the clutch pedal linkage was real sloppy and out of adjustment. Replaced a clevis and took out the extra play, problem solved.
Tanks for your input.
