Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
Blue devil don't work
Post new topic    Yesterday's Tractors Forum Index -> Crawlers, Dozers, Loaders and Backhoes
Cat u9 u9
PostPosted: Sun Sep 09, 2012 6:46 pm    Post subject: Blue devil don't work Reply to specific post Reply with quote
How do you figure out were the psi coming from
If the radatior is blowing all the water out
I've been fighting this old cat 1961 17A
It's plenty strong but won't run cool
New radatior
Cleaned out heat exchanger
Rebult water pump
New complete heads an gaskets
It had a pony motor put on a starter
New turbo and exhaust
All this with in a year she was running good
But stated getting hot more an more
Figured it was pre com r head gasket
Head gasket was blown replaced w/everything
New got the hook up but it didn't fix it
I'm thinking of making it into a steam dozer
Uncle Ernie
PostPosted: Sun Sep 09, 2012 7:13 pm    Post subject: Re: Blue devil don't work Reply to specific post Reply with quote
Are you getting coolant in the oil too? On some engines you can take the pan off, presurize the radiator and watch for coolant leaking down from the cylinders.
You could make an adapter to go into the injector hole and connect to an air compressor. Roll the engine over to TDC compression stroke, pressurize the cylinder and listen for where the air comes out.
NCWayne
PostPosted: Sun Sep 09, 2012 7:33 pm    Post subject: Re: Blue devil don't work Reply to specific post Reply with quote
Probably crazy to mention given all you said you've done, but what about the thermostat? Without a thermostat in place, or with the thermostat stuck wide open, many engines will have enough flow going through the radiator to cause water to come out if the cap is off. Even if it's just stuck wide open the lack of restriction in the system will allow the water to flow too fast and not release enough ehat into the radiator and that alone will cause one to heat. So, if you haven't checked or changed it already I'd definately try that.
Anothetr thing to check on the older machines is the pressure regulator on the radiator. Look just to one side of the fill port for a round disc with several bolts in it. If you take it off there should be a spring, a disc, and another thin plate that acts as a seat under it. Make sure that everything is clean and free to move, that the disc and sealing surface are clean, etc, etc. Too make sure the sealing disc on the main radiator cap is good too so it seals. Without these items in place and working properly the radiator will not build any pressure internally, and, like a standard radiator without a pressure cap, it will not cool like it's supposed to.
I read your post below and the seal rings on the liners will allow coolant into the oil, but they have nothing to do with any kind of compression/ pressure getting into the cooling system. In other words the o-rings on the liners shouldn't be an issue unless you start seeing coolant in your oil.
Sounds like you've done and checked alot of stuff already, but those are a few things I would check first if called out to a customers machine, hope they help.
Fritz Maurer
PostPosted: Sun Sep 09, 2012 7:43 pm    Post subject: Re: Blue devil don't work Reply to specific post Reply with quote
He also didn't mention the oil-soaked V-belts running in U-shaped grooves
Old Magnet
PostPosted: Sun Sep 09, 2012 8:57 pm    Post subject: Re: Blue devil don't work Reply to specific post Reply with quote
Did you check liner height when you changed head gasket?
NCWayne
PostPosted: Mon Sep 10, 2012 12:37 pm    Post subject: Re: Blue devil don't work Reply to specific post Reply with quote
Yep, those can tend to cause a bit of overheating too. Funny thing, had a customer with a newer JD excavator that was having some heating issues last summer. He'd always call from a job in the middle of nowhere when it happened and ask what I thought the problem was. Tried troubeshooting over the phone having him check various things as he was trying to prevent having to prevent me coming so far to get to him ((((ie save money when things were really tight already)))). All of that really got no where, as you'd expect, but finally winter hit and the problem went away. It finally started on him this past summer and all but shut him down. I wasn't avaialble to go look at it at the time so he got someone local, who was recommended by someone at the job site, to come out. The machine had a serpentine belt on it and according to what I was told when the guy checked it, it was tight, and had never made any sound at all. The guy he called installed a new belt, blew out the radiator (something I had already had the guy do long ago) and the heating problem stopped.
I've never heard of a serpentine belt slipping enough to cause the fan or water pumpo to slow down and never make a sound. I have seen something similar on this same customers T190 Bobcat after he replaced two alternators and then brought it to me with a charging problem. Batteries checked OK, alternator checked OK, and the V belt driving the alternaor was tight and made no noise, but was a bit aged and cracked. Replaced the alternator belt and he's had no problems since. In the end the problem isn't always obvious and I guess you learn something new everyday.
Bob/Ont
PostPosted: Mon Sep 10, 2012 2:55 pm    Post subject: Re: Blue devil don't work Reply to specific post Reply with quote
Blown head gasket is most likely a low liner.
Big job to fix right but the only way to go.
Later Bob
shinnery
PostPosted: Mon Sep 10, 2012 9:26 pm    Post subject: Re: Blue devil don't work Reply to specific post Reply with quote
Another serpentine belt type problem I had was a 92 Dodge CTD, with the old belt when the A/C compressor clutch came on the belt would STOP. Engine would keep running fine no smoke and no noise. I replaced the belt and tensioner and everything is happy now. The first symptoms were engine starting to get hot and A/C not working.
Bryce
Smile
Cat u9 u9
PostPosted: Tue Sep 11, 2012 11:31 am    Post subject: Re: Blue devil don't work Reply to specific post Reply with quote
That was some good info it the head gasket
The devil is making trails all over the place
Down the block were its leaking we're going to
Tear it this evening I got a week to fix her an
Continue the job where's the king when u need
Him Thanks for ya ll time it's has helped me
A lot
Cat u9 u9
PostPosted: Tue Sep 11, 2012 8:01 pm    Post subject: Re: Blue devil don't work Reply to specific post Reply with quote
Nope it was higher than the block
And it had a carbon ring that I was told not to
Mess with
No ring groove. That I could feel
Cat u9 u9
PostPosted: Wed Sep 12, 2012 4:26 am    Post subject: Re: Blue devil don't work Reply to specific post Reply with quote
Old Magnet
PostPosted: Wed Sep 12, 2012 6:30 am    Post subject: Re: Blue devil don't work Reply to specific post Reply with quote
Do you know the correct procedure and specs for checking with the liner clamped down?
Bob/Ont
PostPosted: Wed Sep 12, 2012 9:27 am    Post subject: Re: Blue devil don't work Reply to specific post Reply with quote
9U,some things you need to understand, from what I get from your post.
The carbon ring is very good, that is correct.
It means that your rings are not letting any oil past them. Now getting to your major problem the constant blowing gaskets.
Take the old gasket and look where it was blown, you may have more than one spot.
Then look at the liner tops in those areas for any signs of the carbon washed off the liners and pistins.
Then polish the tops of the liners and block clean.
Each liner must be clamped down with an H bar to 60Lb Ft. and the height of it's flange above the block measured with a dial indicator in 4 places around the flange. Projection should be 0.004" to 0.008" with each liner's measurement with in 0.002".
You most likely have a low liner, you can get the piston and rods out the side but if you take the pan off!!! The oil pump and ballancer comes with it!!!! The ballancer weights must be timed upon assembley. ""any piston on TDC and the weights at the bottom.""
Use one of the 1/2" mounting bolts to lock weights untill the gears are engaged, then be sure to take it out.
When you get it apart new liners might not do it, liner seats might need cutting and shimming but will get into that then.
Later Bob
Cat u9 u9
PostPosted: Thu Sep 13, 2012 3:34 am    Post subject: Re: Blue devil don't work Reply to specific post Reply with quote
I'm going to check today thanks bob
