1755
Ron H
PostPosted: Mon Sep 10, 2012 5:15 pm    Post subject: 1755 Reply to specific post Reply with quote
Found a real nice 1755 what should I look for? The owner says 2800 hours with a white cab. Tires are real nice with front weights. The best deal its close to home. Asking 4000. Its a diesel wide front. Thanks
BradWi
PostPosted: Mon Sep 10, 2012 5:30 pm    Post subject: Re: 1755 Reply to specific post Reply with quote
Check the rear end fluid level,overfull may indicate a leaking pto unit.Look in the oil fill hole on the engine for 12 point rod bolts,this will indicate if it has possibly had some engine updates.the water pumps have a weep hole on the bottom side if wet indicates bad pump seals.I also request that it not be started prior to my inspection. Then usually take an 1-1/8" wrench and let the engine oil drain plug almost out of the pan until i get a drip or two to make sure there is no water in the oil.Tractors this age often have failing cylinder sleeve o rings causing coolant to get in the oil.Just my 2cents good luck!they are a nice tractor
