| Author |
Message |
mlansing Regular
Posted: Tue Sep 11, 2012 5:33 pm Post subject: Oliver Cummins Conversion |
Whomever said the 1850 Perkins Flywheel housing would work, might be wrong. Today we tried to measure, line up and get ready to drill holes, but first there was less then a 1/4 inch for the flywheel to fit into the housing. 2nd the flywheel housing does would have get shimmed or cut out around the oil pan to make it work. 3rd once on the starter would not fit for several reasons. (manual Fuel pump is in the way, extremely tight to the block unless you have a stepped reducing starter)
So has anyone ever used them?
Pictures if you have. |
| Back to top |
Wrenchbender Long Time User
Posted: Wed Sep 12, 2012 3:19 am Post subject: Re: Oliver Cummins Conversion |
You need the SAE flywheel housing for a Cummins, part # 3903282. The part you need from a Perkins-1850/2-105 is the clutch housing that bolts the hydra power or over/under to the flywheel housing. WB<><. |
| Back to top |
pup88 New User
Posted: Thu Sep 13, 2012 6:04 pm Post subject: Re: Oliver Cummins Conversion |
We have an 1855 that we put a 5.9 Cummins in we used the Cummins Bell housing1850 clutch housing 1850 belly casting and 2-120 white flywheel |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
