mf 65 timing ?'s
toddol1971
PostPosted: Wed Sep 12, 2012 5:12 pm    Post subject: mf 65 timing ?'s Reply to specific post Reply with quote
my massey 65 g176 continental is slowly getting hot. It can idle all day just fine, but start bushhogging and the temp goes up. It has even died a time or two. Here is the things I"ve done so far. I had the rad cleaned about 10 years ago. Maybe 800 hrs since. change antifreeze every 3 or 4 yrs. New water pump 6 yrs ago. flushed out system 3 times last month and took the t-stat out. it still gets hot. I changed the spark plugs and while out I looked in the holes and the piston and cylinder look gunky. No water that I could see. no water in oil and no oil in water. I did a comp test 175/175/154/175. I pulled the fan and straightened the blades (they weren"t really that bad, I figured what the heck worth a shot). . New rad hoses. The only thing I haven"t done is check the timing. I need to do it. which way advances it? cw or ccw? So, what do youns think? Any ideas? Thank You.
Eric in IL
PostPosted: Wed Sep 12, 2012 6:44 pm    Post subject: Re: mf 65 timing ?'s Reply to specific post Reply with quote
After you get it in time, if it is still running hot try opening the main jet a quarter turn. They will tend to warm up under load if they are set too lean.
Steven-Id
PostPosted: Wed Sep 12, 2012 8:17 pm    Post subject: Re: mf 65 timing ?'s Reply to specific post Reply with quote
My experience with thermostats is that they tend to run hotter without the thermostat than with it(unless of course it was bad). Without the thermostat the water doesn't stay in the radiator long enough to cool down. As far as the timing just pull the distributor cap and watch which way the rotor turns. Turning it the opposite way will advance the timing.
Steven
trac
PostPosted: Thu Sep 13, 2012 7:59 am    Post subject: Re: mf 65 timing ?'s Reply to specific post Reply with quote
I know when i have heat issues when brush hogging my rad. is clogged up grass and stuff i just hose it clean were you can see light though it. I'm sure you have cleaned it out before.
Dieseltech
PostPosted: Fri Sep 14, 2012 11:51 am    Post subject: Re: mf 65 timing ?'s Reply to specific post Reply with quote
I would have distributor advance checked out, it will run hot if advance is stuck in retard position when engine is sped up due to late ignition timing.
toddol1971
PostPosted: Fri Sep 21, 2012 11:53 am    Post subject: Re: mf 65 timing ?'s Reply to specific post Reply with quote
This tractor never ran hot before. I'm pretty sure cw is advancing cause it raises rpms. Last night I was real tired so I didnt wright everything. I pulled the t-stat to see if it worked. It worked fine. (Im assuming you know how I tested it.) I'm not insulting your intelligence but the opposite is true. Taking out the t-stat will make the engine run cooler, well its suppose to. It just didnt in my case cause there is a problem. By not having a t-stat the water is flowing freely thru the rad constantly cooling down the h2glycol. This is if you have a properly working cooling system. Installing the stat causes the water to stop flowing enough to build back up the heat. With out a t-stat or even to cool of a t-stat can cause motor to run rich which leads to carbon fouling of the cylinder, valves and plugs. I know running your timing to retarted will or can cause the same thing and even overheat. These last 2 or 3 things may be whats wrong with mine. I'm gonna check timing and see where its at. I just got my timing lite. I'll report back. I started to post this the other day, or even a week ago, but had a family issue so I'm finally getting to it.
Thanks for all your help.
toddol1971
PostPosted: Tue Sep 25, 2012 8:49 am    Post subject: Re: mf 65 timing ?'s Reply to specific post Reply with quote
Well I did a coolant press test. All is ok. I found the dist tightening bolt stripped out and wouldnt tighten. I replaced this and adjusted timing by ear. I bushhogged for 2 hrs and it never got above 195. I need to look up how to time this thing then check it. any ideas on how to time it. thanks.
