Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
MM UTS Special oil filter
Post new topic    Yesterday's Tractors Forum Index -> Minneapolis Moline
Cjet
PostPosted: Thu Sep 13, 2012 11:31 am    Post subject: MM UTS Special oil filter Reply to specific post Reply with quote
Has anyone found a place to get an oil filter for a UTS special? Mine has the filter in the pan so I can't use a spin on adapter. Engine tag # 283C-4
mm-g706
PostPosted: Thu Sep 13, 2012 1:58 pm    Post subject: Re: MM UTS Special oil filter Reply to specific post Reply with quote
I had the same problem a while back. If you have a lathe you can make two adaptor that will fit the napa 1118 filter this is very simple with very little machining project. If any wants the drawing email me
mightymolinekid
PostPosted: Thu Sep 13, 2012 2:04 pm    Post subject: Re: MM UTS Special oil filter Reply to specific post Reply with quote
I've looked all over for one for my UB Special diesel, with no luck. What I have learned though, is that a filter for a 670 can be made to work with a little engineering. I think they are shorter than the Special filters so you need a spacer to hold it tight to the back of the canister. I haven't tried it because it turns out that mine is missing the canister and original filter from inside the pan. At some point someone drilled into the main oil galley from the outside and mounted a homemade spin on adapter set up. So my remedy is to swap the pan and pump from a straight UB diesel, and the filters are available for that. Not original, but will work. How does the Special system work? I don't see in the pictures where the oil flows through the canister?
WestTxMM
PostPosted: Thu Sep 13, 2012 5:05 pm    Post subject: Re: MM UTS Special oil filter Reply to specific post Reply with quote
Try the guys at Henry Leasing in Bakersfield,CA. (661) 395-3027. They helped me out.
-Doug
Cjet
PostPosted: Thu Sep 13, 2012 5:42 pm    Post subject: Re: MM UTS Special oil filter Reply to specific post Reply with quote
Here some pics of the cover. The oil flows into the cover, then thru a gallery to the filter, then out of the filter thru a return hole back to the pan. I believe I have the flow direction correct , but could be wrong. Maybe someone else can verify.
Cjet
PostPosted: Thu Sep 13, 2012 5:50 pm    Post subject: Re: MM UTS Special oil filter Reply to specific post Reply with quote
Thanks Guy's. Off to the lathe to make an adapter.
Cjet
PostPosted: Fri Sep 14, 2012 5:47 pm    Post subject: Re: MM UTS Special oil filter Reply to specific post Reply with quote
Is the center hole in the napa filter 1118 the same as the original filter? Just wondering if the original retaining nut will work as is.
WestTxMM
PostPosted: Sun Sep 16, 2012 4:57 pm    Post subject: Re: MM UTS Special oil filter Reply to specific post Reply with quote
Tom Barnes @ Henry Leasing had some filters made that should work. They are KE5905. I think they were about $17. Give him a try, beats changing everything out.
-Doug
molinegb
PostPosted: Mon Sep 17, 2012 1:22 pm    Post subject: Re: MM UTS Special oil filter Reply to specific post Reply with quote
I just ordered 2 10B6865's. I had one on shelf but needed a couple of spares.
mm-g706
PostPosted: Tue Sep 18, 2012 1:36 pm    Post subject: Re: MM UTS Special oil filter Reply to specific post Reply with quote
MolineGB
Where did u order the U special filters from thannks
Post new topic    Yesterday's Tractors Forum Index -> Minneapolis Moline All times are GMT - 8 Hours
