| Author |
Message |
carbonfibers Regular
Posted: Fri Sep 14, 2012 11:11 am Post subject: Allis B Starter Alignment |
Is there any way to better align the starter on a 1945 Allis B. I removed my starter for an overhaul and noted that it appears the gears are slightly misaligned because the starter sags a little in the boss fit.
Thanks,
Wayne |
| Back to top |
old Tractor Guru
Joined: 12 Mar 2000 Posts: 50439 Location: Lake of the Ozarks area of MO
Posted: Fri Sep 14, 2012 1:32 pm Post subject: Re: Allis B Starter Alignment |
It only has the tapper bolt to install it so no way to do any thing other then buy a new bolt if you can find one that is |
| Back to top |
steve(ill) Tractor Expert
Posted: Fri Sep 14, 2012 2:29 pm Post subject: Re: Allis B Starter Alignment |
clearance between the starter and case is only a few thousandths. Once the bolt is tight, there is no movement. THe bolt can be made from a 5/8 NC bolt and tapered on a grinder or lathe. |
| Back to top |
Bob Bancroft Tractor Expert
Posted: Fri Sep 14, 2012 2:51 pm Post subject: Re: Allis B Starter Alignment |
I never looked it up or tried it to find out- but I believe the hex head pointed bolt on a WD is the same as yours, which probably has a slot for a screwdriver? With the hex head then you can really get it tight. |
| Back to top |
Posted: Fri Sep 14, 2012 3:22 pm Post subject: Re: Allis B Starter Alignment |
Thanks to everyone for the information. I have the original bolt with the screw driver slot and the hex nut. I can get it tight but it appears to tilt a little at the rear of the starter. I guess it ois Ok since it worked fine since 1945.
Wayne |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
