Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
6v to 12v conv. question
Goto page 1, 2  Next
Post new topic    Yesterday's Tractors Forum Index -> Ford 9N, 2N, 8N
Karl Gant
PostPosted: Fri Sep 14, 2012 2:58 pm    Post subject: 6v to 12v conv. question Reply to specific post Reply with quote
Hello everyone. My question is the following:
when I do the 6v to 12v conversion on my 8N Engine powered tractor, I plan on redoing ALL the ignition stuff(points,condeser, Dist Cap, spark plugs, spark plug wires, rotor, coil, etc.), apart from installing a 12v coil, do I need to be concerned about the other parts being 12 volt compatible? Are most of the replacement electrical parts(stuff I would buy from a catalog/website catering to N's)intended for a 6 volt system only? My gut tells me this is a silly question, but I want to be clear on what I need when I start ordering stuff. Thank you.
JMOR
PostPosted: Fri Sep 14, 2012 3:01 pm    Post subject: Re: 6v to 12v conv. question Reply to specific post Reply with quote
coil is it as far as ignition is concerned.. Otherwise, lights.
Karl Gant
PostPosted: Fri Sep 14, 2012 3:14 pm    Post subject: Re: 6v to 12v conv. question Reply to specific post Reply with quote
Awesome. Thanks very much!
David G
PostPosted: Fri Sep 14, 2012 3:56 pm    Post subject: Re: 6v to 12v conv. question Reply to specific post Reply with quote
Coil or resistor for coil and lights. I would not change out everything at once. Do the 12V conversion, make sure it runs, then do the tune up. It is really hard to troubleshoot when you change more than one thing at a time.
36 Coupe
PostPosted: Fri Sep 14, 2012 4:05 pm    Post subject: Re: 6v to 12v conv. question Reply to specific post Reply with quote
Why change all the ignition parts?
Karl Gant
PostPosted: Fri Sep 14, 2012 5:31 pm    Post subject: Re: 6v to 12v conv. question Reply to specific post Reply with quote
Got it. Good point.
Karl Gant
PostPosted: Fri Sep 14, 2012 5:38 pm    Post subject: Re: 6v to 12v conv. question Reply to specific post Reply with quote
I just figured it would be a good idea, so I could get a solid baseline. I have no idea what the age is of all the items currently on the tractor. Since they are maintenance items, and I'm converting to 12v anyway, just do it all at once. This rig runs, but it needs to be gone thru completely, from a mechanical standpoint, b/c I don't know how well it has been maintained.
old
PostPosted: Fri Sep 14, 2012 5:54 pm    Post subject: Re: 6v to 12v conv. question Reply to specific post Reply with quote
8N engine can be front or side mount distributor which do you have??? Then we can go from there to tell you which way you need to go.
Dell (WA)
PostPosted: Fri Sep 14, 2012 8:05 pm    Post subject: Re: 6v to 12v conv. question Reply to specific post Reply with quote
Karl.......we've all flunked mind reading, so you really need to tell us iff'n yer dizzy is the weird 4-nipple frontmount ...or... the 5-nipple sidemount. You can count nipples can't you???
Surprizingly enuff, yer points and condenser are good fer about 200V, so 12V is NOT a problem.
The other thing you need to do is make certain ALL lights are changed to 12V.
And remember, even the 4-nipple 12V squarecan frontmount coil needs the MANDATORY "infamous ballast resistor".....NO ARGUE!!! .......Dell, yer self-appointed sparkie-meister who knows 8-ways to convert to 12-volts and they all work the first time
Karl Gant
PostPosted: Fri Sep 14, 2012 8:10 pm    Post subject: Re: 6v to 12v conv. question Reply to specific post Reply with quote
side mount dizzy.
Karl Gant
PostPosted: Fri Sep 14, 2012 8:19 pm    Post subject: Re: 6v to 12v conv. question Reply to specific post Reply with quote
Definitely have the 5 nipple version. Thankfully, no lights to mess with...I plan on adding those later(much later)down the road.
oldtanker
PostPosted: Fri Sep 14, 2012 8:24 pm    Post subject: Re: 6v to 12v conv. question Reply to specific post Reply with quote
Karl, with the side mount you can use the 12 volt no external resitor required coil. Point and condenser don't really care about voltage. Add 12 volt lights and yer good to go.
Now if there are other mechanical issued....like low compression fix those problems first. 12 volt is an upgrade not a band aid.
Rick....with 2 N's converted to 12.....one IE.
Dell (WA)
PostPosted: Fri Sep 14, 2012 8:33 pm    Post subject: Re: 6v to 12v conv. question Reply to specific post Reply with quote
Karl........for the 5-nipple 12V conversion, we recommend the NAPA IC-14 roundcan coil, NO RESISTOR EVER. ($18, cheap) And it has HOTTER sparkies too. ........Dell, sparkie-meister
Karl Gant
PostPosted: Fri Sep 14, 2012 8:46 pm    Post subject: Re: 6v to 12v conv. question Reply to specific post Reply with quote
This is all fantastic info. Thanks so much for the speedy responses. The condition the tractor is in now is kind of: "where do I begin?" I have to have the radiator re-cored, the hoses are on their last legs, might as well get a new t-stat too...carb, I'm sure, could use a rebuild...plan on doing that, the outer jacketing/cover on the plug wires is cracked(2 wires are completely missing boots at the plug end). Don't know when the oil was last changed. This particular engine doesn't have an oil filter(which I found peculiar, until some fellow owners on another forum told me that it wasn't unusual). So, I'm going to plug away at these items just to get to where I can see what else needs to be done. Wish i knew how to post a pic, then you all could see what I'm up against(ha!). Looking forward to diggin into it regardless.
Ultradog MN
PostPosted: Fri Sep 14, 2012 10:02 pm    Post subject: Re: 6v to 12v conv. question Reply to specific post Reply with quote
When you get done with your conversion you will have years of trouble free tractoring. At least electrically.
12V is the only way to go.
Goto page 1, 2  Next
Page 1 of 2
