Farmall m NEED HELP
Red49
PostPosted: Sun Sep 16, 2012 10:45 am    Post subject: Farmall m NEED HELP Reply to specific post Reply with quote
Got a farmall m thats puting down about 85hp. Will turn 3000rpms. But when i get about 3/4 of the way down the track it just pulls down and will die. I had a old m and it would lug out a full pull. Think timing could be out? Just trying to get it to lug. Thanks for any help!
42 M
PostPosted: Sun Sep 16, 2012 11:33 am    Post subject: Re: Farmall m NEED HELP Reply to specific post Reply with quote
Are you sucking the carb dry? Maybe fuel flow is not enough at full throttle for that long. Try hooking a 2 or 3 bottom plow and run it at full power and see if it still does it. If so try 3/4 throttle if it stops bogging down you need more fuel. I found this to be my problem on my JD A. Turned out the fuel bowl on the tank was plugged only enough so it would not run at full throttle.
Red49
PostPosted: Sun Sep 16, 2012 2:14 pm    Post subject: Re: Farmall m NEED HELP Reply to specific post Reply with quote
Ok i think ill try hooking it up to my 1066 with a disk and let it drag the ground. Thanks for the help!!!!
Underdog Moline
PostPosted: Sun Sep 16, 2012 6:46 pm    Post subject: Re: Farmall m NEED HELP Reply to specific post Reply with quote
Fuel cap venting?
bp4455
PostPosted: Mon Sep 17, 2012 5:28 am    Post subject: Re: Farmall m NEED HELP Reply to specific post Reply with quote
get a fuel pump cant go wrong that way.
red49
PostPosted: Mon Sep 17, 2012 6:33 am    Post subject: Re: Farmall m NEED HELP Reply to specific post Reply with quote
well the guy i got the tractor from put a after market type of cap on it i think ill put the one off my h on there n see if that helps. thanks for the help again
red49
PostPosted: Mon Sep 17, 2012 5:59 pm    Post subject: Re: Farmall m NEED HELP Reply to specific post Reply with quote
Thanks for the help got the fule pump on....
Red49
PostPosted: Mon Sep 17, 2012 6:03 pm    Post subject: Re: Farmall m NEED HELP Reply to specific post Reply with quote
Pulling
Post new topic    Yesterday's Tractors Forum Index -> Tractor Pulling All times are GMT - 8 Hours
